Question about Panasonic NN-S762 Microwave Oven
After a power outage in the house the microwave went dead. There is no display. When you open the door the light turns on and the fan turns on. I opened it up and the fuse is o.k. I noticed that there is a burn on the pc board etch that the display is attached to.One track look to be burned,around the small transformer, Varester. Will repairing the track fix it or will it just burn again?
  • 1,606 Answers
Usually if there was enough power to burn the traces then it usually will damage a few things. It's worth a try to fix the trace. If it works don't be too surprised if it fails later on.
Posted on Apr 28, 2010
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
EVERY PART OF THE MICROWAVE STOPPED WORKING
There is an internal fuse inside. Need to find the cause for it blowing or it will just go again. Check the monitor switch and door switches. Eric
Aug 08, 2009 | Jenn-Air JMV8208AAS Microwave Oven
No heat, does not cook
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No Power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 665.61639100 quit working
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Kenmore 62702 Microwave Oven
No power
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
We have the full service manual, and I have uploaded it to our site here.
The best place to order Sharp parts is Tritronics at http://www.wehaveparts.com
Once you have it fixed, if you would like for us to replace your display on the control board, we can install a new display tube for $69.95 or a good used one for $54.95 and those totals include return shipping.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 06, 2008 | Sharp R-1480 Microwave Oven
Sharp R510AK Carousel Microwave
Very common problem with the display. It may or may not eventually light back up on it's own.
I would suggest contacting www.microwavedisplay.com. Lots of info and the best deal going for repairing the display.
Jul 03, 2008 | Sharp R-510HW Microwave Oven
Dead microwave
You have likely blown the thermal fuse, its a small silver 1/2" pointy wire on each end and secured by clamp and normally brass crimps to the wires.
usually attached around the fan or motor area.
see this picture
http://chinafuse.en.alibaba.com/product/50391300/50098721/thermal_fuse/Thermal_Fuse/showimg.html
Jan 27, 2008 | Maytag MMV4205 Microwave Oven
Reset Microwave after a Power Outage
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
Sep 11, 2006 | Goldstar MV-1526 Microwave Oven
Panasonic NN-S762 Microwave Oven Logo
133 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
