Question about Goodman CLT30AER36 Air Conditioner
Inside coil freeze over - Goodman CLT30AER36 Air Conditioner
    Guru:
  • 1,524 Answers
Can be caused by dirty filter, restricted air flow, fan motor slowing down.
Posted on Apr 28, 2010
Fix freeze up
There is a reason they freeze up 1. low on freon..2 evaporator coil needs cleaning(inside coil)..3. very dirty air filter, any one of these for a an air conditioner may freeze up... due to a number of other reasons. The most common reason for an air conditioner to freeze up is low on refrigerant.
Jun 27, 2015 | Heating & Cooling
Ac freezing
for a homeowner the first thing to check is the filter. also make sure the fan inside is running. once the coil freezes it does make it more difficult to push air so coil must thaw. don't continue to run unit if you see ice, you are only harming the system. if checks are good you likely have refrigerant issues and need a technician
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 06, 2018 | Goldstar WG5000 Air Conditioner
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Have a true ttp67 that freezes when turned on after 2-3 hours instead of cooling!
If it was off over night the fan comes on you should feel air coming from the inside vent the condensor fan may be bad or the blade is loose
If you feel air then it freezes it's a Classic example of low freon gas.
Oct 02, 2009 | True GDM-26 Refrigerator
Ac freezing outside not inside
If its in the cooling mode the ice is in both places. It freezes up inside first then works its way outside just usually not easy to see the inside ice because its incased in the coil box. This could be due to a lack of airflow ie dirty filter coil or closed dampers or low on freon. If its a heat pump and in the heating mode it could be a bad defrost control, lack of airflow across the outdoor coil or low on freon.
Sep 12, 2009 | Honeywell Electronic Programmable...
Coils freezing
coil freezing is a sign of under charged system. Contact aized service center for recharging of refrigerant.
I hope this helps.
Jul 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
Coil freezes up
Usually when the indoor coil freezes up you either have dirty filters or coil but if you had this unit replaced last year your coil and filters are probably OK so you probably have a leak in the unit and are low on refrigerant.
Apr 24, 2009 | Heating & Cooling
Air condition unit will not cool and the coils freeze up in just a few min.
Is the inside fan running properly? Typically if the condensor outside is working, but the fan inside is not, the coils will freeze up quickly. For the system to work properly, you need to be blowing warmer air over the coils inside the house- that then brings the temp of the refrigerant in the coils back up, and the loop continues. If the fan inside is not working, check to make sure that the circuit breaker is not tripped.
Jul 06, 2008 | Intertherm Heating & Cooling
Goodman CLT30AER36 Air Conditioner Logo
65 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
