Question about Singer 7436 - INGENUITY
Singer 7442 Bobbin Will not wind
Whenever I engage the bobbin to wind, and press the foot switch, it immediately locks up and all lights light up. To get it to do anything but blink, I have to flip the on/off switch. Then it starts for just a second, winds two or three rounds and locked up again, with a high pitched electronic squeal, all lights blinking again.
I have a singer 7436 and the same thing is happening!  How can I fix this?
  • 2 more comments
  • BigO55 May 13, 2008
    singer 7422 has thread loaded per the instructions in the manual, but when you press the foot presser nothing happens!
  • Anonymous Apr 17, 2009
    Just got off the phone with customer support and they told me it might be the alarm for the tensioner. To fix it I will have to send it to a warranty center the is 3 states away! I might keep trying it on my own.
  • Anonymous Mar 22, 2014
    started to wind the bobbin, started ok then high pitched tone,stopped and error code e2
  • Anonymous Mar 30, 2014
    The bobbin starts to wind and seizes and all the red lights next to the stitch patterns blink.
This happened to me on / off before but now seems ok since I cleaned the area where i put the bobbin when sewing. There was so much lint - I guess it was playing a role.
Posted on Apr 12, 2012
To wind a bobbin you get thread and put it where it usually would be put it behind those 2 metal piece (see pic in manual) and there put it around the thread guide and then u put the tip of the thread through the hole of the top of the bobbin from the inside to the outside  and u are really to start, u should already have the bobbin and the spinning metal piece, then u move the metal piece to the right into the notch and press the presser foot and hold it until it stops you and you're done :-)
Posted on Mar 27, 2008
Singer Touchtronic 2000 - it will not wind a bobbin, I have found a manual onlin that says you just drop it in and push the foot feed and it will wind the bobbin but it doesn't do anything.
Take your thread that is under the presser foot and wind the thread on the tension disk. It is located right above and to the left of the presser foot. Then you will drop in the bobbin and slide the thread into the **** in the top of the bobbin. Push the little white tab in the bobbin slot all the way to the right until it is in the center of the bobbin. Then press the foot feed and the bobbin should wind.
Oct 24, 2010 | Singer Sewing Machines
We have 2 singer 7442 machines and they will no longer wind the bobbin. Up to this point we followed the instructions the manual gave on how to thread and wind the bobbin. How do we fix?
If you have followed the instructions and the winders do not work, the machines will need to be repaired, or you could purchase a Sidewinder Bobbin Winder and forgo the expense of having the machines repaired.
Mar 08, 2010 | Singer 7442 Mechanical Sewing Machine
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
Apr 06, 2009 | Singer 7436 - INGENUITY
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
I accidentally used 220V for my singer 7442, I don't know if there is a fuse that I can change? can someone help me with this?
Jan 19, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7436 - INGENUITY Logo
312 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
