Question about LG LFX25960ST Stainless Steel French Door Refrigerator
LEAKING FROM BOTTOM RIGHT CORNER
OUR FRIG LEAKS FROM THE BOTTOM RIGHT CORNER. APPEARS TO BE ORIGINATING FROM THE BACK OF THE UNIT BUT I CANNOT GET INTO IT.
    Guru:
  • 1,524 Answers
Either leaking water valve, or possible cracked drain pan.
Posted on Apr 28, 2010
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
Tip
Full Reset to original factory status May cure many problems
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Sep 21, 2007 | Garmin StreetPilot C330 GPS Receiver
Why is there water dripping from the bottom of the water/ice dispenser
The solenoid valve that controls the water dispenser is leaking internally. It will be a double valve (one for ice, the other for chilled water) located at the bottom of the frame in the back of the unit. To find it, just trace where the plastic tubes originate from.
Easy to replace.
These leaks are sometimes caused by particles getting trapped on the valve seat. This can be prevented by use of an inline water filter on the copper supply line.
Oct 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
Freon gas leaking from frigidaire refrigerator
Hello nmatthews748 - Once you have experienced a gas leak, I highly recommend unplugging the unit. For safety and liability reasons we do not suggest that you troubleshoot this yourself any further and to contact a professional to move forward accurately
Nov 22, 2012 | Frigidaire Refrigerators
Hoover Dishwasher HD95M leaks on start up from bottom right front corner. Leaks when initially being fed from water feed.
Water leaking can be poor plumbing or fault in the inlet hose connection. You are the first observer and so your view on the leak area is important as the leak can be from the hose, from the inlet, the hose or the washer unit.
Based on this the water leak can be plugged, tighten the hose clips, check the inlet filter or check the washer's feed line.
Feb 09, 2011 | Hoover HD95M Free-standing Dishwasher
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Add'l info
From description looks like the leak in where the shorted hose had been connected, or the pipe has another leak.
Wrap the hose with a cloth, on the side where it goes inside the cabinet, so that you find out if the leak is coming from the inside or from the outside part.
Ensure that it is not coondensation.
Sep 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water leaking from bottom of unit
For original poster: Check all milky white colored (polyethelne) plastic water lines. These lines tend to get brittle and can crack over a period of time. They extend from the water valve to the ice maker, and from the water valve to the inside of the refrig to a "radiator" so the water can chill, before it runs back out the refrig, past the left side of the refrig behind the bottom grill, through a coupler, and up through the bottom hinge of the freezer door. I'd also advise putting in a separate shut off for the water supply to the refrig so you can have water to the rest of your house when you have a problem with the refrig.
For next user with similar problem: you can check the above, but it may be that the defrost drain is plugged. (on a S x S unit, it is located at the bottom of the freezer compartment, behind the back wall.) If you have a layer of ice on the floor of the freezer, that's a dead give away of a blocked defrost drain tube, Use a turkey baster with hot (not boiling) water to flush it out.
Aug 31, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
273 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
