Question about Lexmark X4875 InkJet Printer
Printer was installed but does not operate..gives a message that the program cannot run with your current display settings at least 800x600 at least 256 colors. I have tried to adjust the display settings..no change. mycomputer is operating omn Window 7.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Try going to manufactures website and updating your drivers. Look for newest driver and also check if it's compatible with Windows 7. This should help you with an issue. Good Luck
Posted on Apr 28, 2010
I have the driver but it said that i cannot continuie installing in windows xp home because the resolution of the netbook is 1024x768.it should be 800x600.what should i do to install the driver...
go to your start menu - control panel- display - settings then adjust the pixells to 800x600 then apply
then check if it will continue installing
Mar 18, 2011 | Computers & Internet
The driver I installed is giving command error message on the printer display. I gues Am using wrong driver. The printer is zebra p420c. I need another current driver. Thanks
Hello:
First go to the printers makers website and click on support, here you will be able to download the right drivers and manuals, even some of software that came with the printer. U did not mention which kind of printer to have.
Nov 10, 2010 | Computers & Internet
When I set the screen resolution other than 800X600 this error on screen comes up "Out of Range!" How to fix this?
Hello Ajay,
This problem is due to the graphics. There can be two reasons one is that you output device is not supporting more than 800*600 resolution, that is why its giving this error.
OR:
The graphics is not installed in the computer you can check the graphics whether installed or not out here.
Click on Start->Run->"devmgmt.msc" without quotes.
and check over there whether you can find a yellow triangle over display drivers or not. And install the graphics for the same and then you can set the screen resolution more than 800*600.
Thanks.
Oct 18, 2010 | Computers & Internet
I'nm trying to install an HP Officejet 4300 driver
  1. Remove your previous installation of that printer. Delete the printer icon in the Printer's folder if there exists.
  2. Reinstall the printer. During installation, choose Custom Install if there is an option like that.
  3. Then choose to install ONLY the printer DRIVERS and do not install the HP Software bundled with the printer. The HP Imaging software conflicts with screen resolution of some devices. Give it a try and see if you can use your printer installed that way.
Feb 26, 2010 | Dell Inspiron Mini 10 Notebook
The unit displays 'Not Optimum Mode 1280 x 1024 using vista
Ok, try another setting say 1024x768, 800x600 & see if that helps, what this means is for whatever reason "Windows" thinks that the current screen settings, aren't the best, for what is being "Run".
Feb 01, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Scannig
that's on your display settings for your monitor..assuming you are on xp, go to start, settings/control panel/display settings/settings, and make adjustments there..
Apr 19, 2008 | Lexmark X2500 All-In-One Printer
Preset
Without knowing any more about your system I can only give you a couple of general ideas.
First try updating to the newest video card drivers possible.
You can try going to the drivers tab in display adapters in device manager and click update drivers.
Failing this, if your system is more than a few years old you will probably have to update to a more current video card to get the resolution that you need.
The native resolution for your screen is 1280x1024.
Jan 03, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Problem in install winxp
Your upgrade options
If you want to upgrade your system to Windows XP, the first thing you need to do is verify that it meets the system requirements for the newer operating system.
You will need:
  • Windows 98 or later version of Microsoft Windows operating system.
  • At least a 233Mhz processor. Any manufacturer (AMD, Intel, IBM, VIA, etc.) will do.
  • At least 128MB of system memory.
  • 1.5 Gigabytes of free hard drive space (note that you should have at least 3 gigabytes if you want to do any meaningful work with your system after the upgrade).
  • A CD-Rom or CD/RW drive.
  • Mouse and keyboard (either USB or PS/2).
  • A video adaptor and monitor capable of displaying 800x600 resolution. If you are not sure about this, change the resolution within Windows 98 by right clicking on an empty area of the desktop and selecting 'properties' then going to the 'settings' tab. The resolution slider is at the bottom left. Set it to '800x600' and click 'apply.' If your screen is still legible, you are fine. If the 800x600 option is unavailable, you may need to upgrade your video adaptor before upgrading Windows.
Note that if the screen becomes scrambled, blank or unreadable, you will probably need a new monitor as your current one cannot handle the required resolution. If your system meets the minimum requirements for Windows XP, it's time to find out which version of the operating system you can upgrade to.
This is Microsofts recommendations
Sean
Dec 11, 2007 | NEC PGA370 SIS620 ATX Motherboard...
Lexmark X4875 InkJet Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
