Question about Amana Refrigerators
Where is the compressor motor capacitor located
I have an Amana refrigerator model TC18MBW, perhaps 25 years old that no longer cools. The fan hums, there is a click-clack sound (I assume this is the motor relay trying to start the compressor). This sound is heard about every thirty seconds. Normally the compressor starts up with a distinctive deeper hum. It is not kicking in. I have been advised the motor capacitor may have failed (a better failure than total failure of the compressor itself). I anm willing to try replacing this part but can't locate it. Can you tell me where it is located. I've openned the rear access panel, the compressor is to the right (a black object roughly the size and shape of a gallon paint can. The fan is about 6 inches to the left. I have seen on a parts website what was labeled as the capacitor (a black box roughly 2.5"x1.5"). I can't quite see it.
My first google search
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
SOURCE: whirl pool side by side refrigerator problem
It looks like the Capacitor Start Relay is failing.  It is located either on the starter Relay or mounted on the side of the compressor compartment.  It sould have two wires on it, one orange and the other probably white.
Posted on Oct 22, 2007
  • 89 Answers
SOURCE: 26 Cu Ft Side By Side Maytag Refrigerator: Relay Failures
you have more than likely got a bad compressor it is pulling to many amps you need to replace the compressor
Posted on Jul 12, 2009
  • 145 Answers
SOURCE: Frig. is 5 years old - Not cooling - Buzzing clicking sound
Sounds like the compressor or start relay have went out.
For any recall info you would need to give the full model and serial to the Maytag.
jim
Posted on Jul 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: We have an Amana ARB1917CW refrigerator about 6
I concur, test the relay- Check your compressor relay-
http ://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Posted on Sep 21, 2009
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Apr 09, 2013 | Amana Refrigerators
Amana Bottom Freezer, Neither freezer nor refrigerator is cooling
Contact the repairclinic.com for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Apr 20, 2017 | Amana ARB1917CSR Bottom Freezer...
I have an Amana Side by side ARS266KBW. Air is blowing, but it is not cool. I hear a click as if the compressor is trying to turn on, but hear nothing after that.
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
Mar 30, 2010 | Amana ARS266KB Side by Side Refrigerator
My model ACD2234HRQ is approx 90 days out of
you need to replace the rtc overload contactor located on the compressor body,there is also a run capacitor on the contactor,replace this along with the rtc contactor,this is your problem,the contactor and overload give the compressor starting power and run power to the windings,if the capacitor is bad it doesnt have enough torque to overcome the power to turn the compressor initially
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana Fridge that won't keep cooling.
Inside your refrigerator fresh food compartment and behind the control panel is a Adaptive Defrost Board this could be the problem or the start relay and start capacitor located on the compressor. I would unplug and examine the defrost board first to see if it looks abnormal. Second I would replace the parts mentioned at the compressor if the Adaptive Defrost Board looks ok. Below is a link that you enter your model number in the model parts search feature. The part number for the Adaptive Defrost is 611005988
Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 28, 2009 | Amana DRSE663B Side by Side Refrigerator
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Whirl pool side by side refrigerator problem
Oct 22, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
54 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
