Question about Viking DDSB483 Side by Side Refrigerator
Water dispenser not working
Water dispenser on the door stopped working. The light turns on and you can hear the motor working inside the door but no water comes out. I tried changing the filter but no change. The filter did fill with water. The ice maker seems to be making ice but I will empty it and confirm that it is working.
I had the same problem. Your water line is frozen. Turn off your freezer and the water line will unfreeze and it will work. You can see about putting in a heater on your water line. There have been mixed reviews on whether or not it works. The water line just froze again, so I may try the heater.
Posted on Aug 16, 2010
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
Inside filter water dispenser suddenly stopped working. New filter removed and no working with or without filter . Water line is fine. Ice maker works.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Mar 18, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
There is no water coming out of the water dispenser. I changed the filter and check the water line coming from the pipe, there is water coming thru the water line. when I push the water dispenser lever I...
Well, there is no "motor" for the water dispenser, only a solenoid valve. However, there could still be a problem with the solenoid even if you do hear it when its energized. Hearing it make a noise does not mean its working properly.
Aug 13, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
The frigde stopped dispensing water. I replaced the inside the fridge water filter, but it still doesn't dispense water. The ice maker is ok so it's getting water. Any ideas on what I can try next?
OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 10, 2009 | Refrigerators
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Water and Ice does not work. Ice dispenser does not even turn.
There is a motor that turns the auger for ice at the door but it has nothing to do with the water at the door. If you are sure the water line at the door isn't frozen then I'd suspect the control board isn't working (no power to the motor or the water solenoid valve). These diagrams may help you see what's inside so you can look deeper into the issue. If you can, try turning the ice auger by hand (dump all the ice out first). Also check that melted ice didn't re-freeze and bind up the auger, etc. If you can leave the fridge off a day with the freezer door open that would melt any frozen water line, just to be sure that's not the problem. http://www.partselect.com/Schematics/Frigidaire/6VV40M4Y.gif http://www.partselect.com/Schematics/Frigidaire/P3WRBSB1.gif
Jan 14, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Viking DDSB483 Side by Side Refrigerator Logo
707 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
