Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv will not turn on. power light will come on, tv
Tv will not turn on. power light will come on, tv will hiss then go out again without any picture ever showing
  • 59 Answers
It my be power supply components.
good luck
Posted on Apr 28, 2010
I have no screen or sound the power light stays on for 5 seconds then goes out again
Get the TV model number and chassis version from the back panel and try
http://www.coppelltvrepair.com/Diagnose/
I wish I could be more helpful, but without those two pieces there's really nothing more I could do.
Mar 26, 2013 | Sanyo 42 in. LCD TV
Philips tv hisses then turns it's self off then back on again
The main power regulator board to this TV should be troubleshooted. Replacement might be necessary as there is no repair to this board.
Nov 20, 2012 | Mitsubishi LT46164 LCD TV
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
TV will not turn on from Stand By mode
if you are comfortable taking the back cover off, do it and visually inspect a cylindrical shaped components on the power supply unit... if you can send a picture please do s69joe@hotmail.com
Dec 08, 2008 | Akai LCT2715 27 in. LCD Television
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
MITSUBISHI TV STOPPED WORKING
If you can do self test diagnosis, read threads here on Mits, or goto ctechnicians.com
Dec 16, 2007 | Televison & Video
Hissing Sound
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Jun 22, 2007 | Durabrand DU1901 TV
No sound or Picture, Just a hissing sound.
well what sounds like happened is you blew up the tube in it. have you unplugged it from the wall and just let it sit some times that helps because what will happen is there will be a Electrical build up and it won't work right. an other thing you might want to do is hit the Degauss button on the remote. plug some sort of video signal into it and go through the inputs to see if that helps, mine did that every thing would just be black but i plug in my video camera it would detect it and make sure that the audio cables are plugged in these TV might just be that old that they have to have both audio and video in order to work.
Nov 27, 2006 | NetTV DTV34XF3 34" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
209 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
