Xfx 8800gt 512MB
Constant 3d lockups... cant run 3d test or games, i managed to get CS:source to work for and maybe an hour before it crashes, after i used ATi Tool to underclock it by 100MHz on the core and mem. clock. I have 4 case fans(tried several dif. layouts), but my temp. usually crashes at only 57-59C. Ive read many forums and most say its faulty drivers, or overheating. Ive also tried a few dif. drivers. Nothing seems to make it stable... PLSSSS HELP
  • Ricky1880 Mar 24, 2008
    Yes its new, 2 weeks. I have heard about the reseal option, ill try that if it doesnt void warranty. As for the fan on the GPU its about 3 inches from the side panel fan which ive tried in both directions. But if the casefan is pointed at the card wouldnt it be clashing with the output air from the GPU fan? Does it work better like that? Thanks for comments, more will be appreciated.
  • 1,019 Answers
These can get warm/Hot under constant use.
If it,s new i,d suggest you may have a faulty card.
I,m not sure whether you can actually remove the fan from the GPU Chip, but if you can.
I,d reseal with a quality thermal compound such as arctic-silver or similar. Theres a possibility that the card has overheated and damaged the thermal-seal between gpu and heatsink.
The other option, is to direct a fan blowing cool air towards the card, rather than trying to extract air from it.
If it,s new it,s faulty ( get it replaced )
If i can be of any further assistance/help.
Please post here.
Many thanks mike @ compurepair.
Posted on Mar 24, 2008
  • Mike Waldron Mar 26, 2008
    I would,nt even be on here posting about this.
    If it,s New return it for replacement.
    just state the problems youre having, and get it return/replaced.
    if you have the same issues with the replacement, then your motherboards the issue and not the card.
    As for the gpu air conditions, it,s just my personnal opinion. for many years manufacturers have only looked in 1 direction. hot air extraction. my theory is to blow cool air at the overheating object. it,s trial and error. find out what works for you.
    Regards Mike @ Compurepair.
Pc keeps crashing during online gaming
This sounds like either a case of graphical artifacting, or your pc is simply crashing.
Graphical artifacts are things not normally seen on your monitor created by overuse of the graphics card, such things as white pigments and the odd pixel patterns you saw are some signs of this. I've experienced this problem, and have had the speakers make the noise you heard noise upon restarting the pc. To see if this is the cause I would try running an extremely graphically intensive game or program such as a 3D benchmark to test the limits of the graphics card, and if you see the odd pixelation during the testing, then it is most likely that the card is the problem, and you should call its manufacturer for a replacement.
If your pc is simply crashing then either your power supply is not putting out enough power for you graphics card, or the graphics card is not hooked up to the motherboard properly. The first to do to check if this is the case is to run your pc until it crashes and see how hot your pc has gotten, if it is very hot, then your power supply could be overloaded, or you may not have enough airflow in the case. I would suggest opening your pc and looking for anything out of place, and even perhaps getting professional help from a technology store.
Oct 12, 2012 | XFX AMD Radeon HD 6770 Graphics Card...
8800gt wont boot my 8800gtx will so it not power related please help
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
As your 8800GTX boots fine and your 8800GT does not boot one would say that your 8800GT is faulty.
How faulty one does not know, does the fan spin? If so then there is some life left in it.
A technician might replace the capacitors for a fee, this may get it working again.
There is not much else on can do but give it to a computer technician to try and repair it.
Feb 11, 2011 | XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI...
My monitor has no input signal when i plug it on my xfx 8800gt alphadog. i've been using it for almost 5 mos, then all of a sudden, when i start my PC my mmonitor is ok but after 3-5 minutes it says no...
your card is probably overheating. the alphadog editon has an extremly small cooling for the gpu. try cleaning it with a caned air spray and check the NVIDIA control panel to see the temp. of the GPU if the problem is solved try running a game benchmark to see if that works.
Feb 24, 2009 | XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI...
Geforce 8600 gts drivers crash and recover moments later
Sorry for the bad news, but you've seem to have witnessed a graphic card meltdown...
During games, cards get quite melting hot! If there's a little problem or inefficiency in the card cooling system (Active Fan or Passive Airflow) Your card will simply melt a few little contacts, enough to produce what you saw or even worse!. (Basically just in the graphic 3D render portion of the board, thats why you could still see windows some times but Aero (3D) started glitching later).
If you wish, you can verify this at your own risk opening up your case and placing your finger on the free corner of your card and bending/arching it a little to the sides when windows or your games are running... It may restore contact at the melted away points for a few seconds for you to see, but won't repair it, you'll maybe see how images get better or worse with the bending, proving the meltdown situation.
Return your card if you can or buy a new one, before the crashes mess up your windows. Buy a new one from a good manufacturer and clad with an elaborated cooling system, if you plan to run 3D heavy games, stay away from the weird branded, cheapest or heavily discounted cards are usually the ones most prone to fail this way. If you go ATI, buy ATI made cards. If you go NVidia, buy BFG for example.
Jan 07, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Dear friends, i am also getting this During the startup I get 2 beeps, first one on the Intel logo screen , and then another slightly longer beep right before Windows loading screen  i need help!  my...
try running a memmory test on your memmory. I use "Hiren's Boot Disk" to run these kinds of checks. If your RAM has any problems, it will show it.
Also, does the game crash and return you to your desktop? Or does the PC reboot? Or does it Blue Screen?
It also "might" be incompatability?
Jan 05, 2009 | Computers & Internet
Pc games hang in the middle of the game
1st on the list drivers
2nd ram
3rd faulty video card
do a fresh intall on another hard disk and then install driver and game see if it works if it does drivers if not ram.
Dec 30, 2008 | XFX NVIDIA GeForce 8500 Graphic Card
Infinite loop error
First try to pop the 8800gt into a friend's computer, if it works for them uninstall and re-install drivers yet again, followed by a format if appropriate. If it does not work, try to get a RMA on the card.
Dec 20, 2008 | XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI...
Gateway FX7026 w/ 8800GT 512MB Video Card / Vista 64 Premium OS
It is a known issue. It is not a fault with the card, but a power saving method used by Nvidia. If the card is not being stressed, or even if it is, it will clock down to it's 2d speeds. This is fine if you are just surfing the web or other light tasks, but can cause chaos if you are gaming or folding at home.
You can force your card to run at it's maximum clocks in 3d mode by using a program called Riva Tuner. There are several good posts on the net on how to use this fix, but I can't seem to link to them as this site will not allow me??
I am using it myself, as I had the same issue with my 2 GTX 260's.
Nov 01, 2008 | PNY XLR8 GeForce 8800GT 512MB PCI Express...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
