Question about ViewSonic VA1930WM LCD Monitor
Widen view to go across two screens - cannot now return to single
Using the monitor controls (1 & 2) widened the view to go across my two screen. Now I cannot find how to get it back to single monitor view Please Help?
  • 1,606 Answers
Go to display and then settings. Usually there is a check box that says something like extend desktop. Just uncheck that, hit apply and you should be back to one screen again.
You can get to the display properties either by an icon by the clock if your video card uses a manager or by right clicking on a blank spot on your desktop then select properties and the display manager comes up. Then just click on the settings tab.
And if nothing else unplug the video cable to the second monitor. the card should detect the change and set itself back to one screen.
Posted on Apr 28, 2010
  • 4,924 Answers
Go to the video card driver manager ..(probably present in teh tray system in the right side on the task bar ) open it ..and default any setting s...
another thing to verify is the enabling or disabling of the second monitor...if you disable it ...this will default the view also to a single display
for laptops the short cut for this on keyboard is FN+F4..
but if it is a desktop ..Im not sure if it will work or not...anyway ..just look on the video card driver manager ...right click on it ..and open options or settings ..there you will find almost all you need for settings..
Widen the screen on Westinghouse tv
Screens are controlled by ASPECT RATIO.
Monitors can have 4:3 16:9 and 16:10 ratios.
You are doing 1 of 3 things.
  1. You have a regular monitor and the tv and are duplicating the screen.
  2. You have a regular monitor and the TV and are extending the screen.
  3. You have just the tv connected.
Your video card has to have a screen resolution that meets the tv's ratio to have the tv take the full screen.
If your configuration is 1. the tv will only match the monitor resolution, so if you change the screen resolution, you may get bars on the monitor, and the tv will go wide screen.
if your configuration is 2. the tv is controlled independently and you can select it to change its resolution to an appropriate aspect resolution. *this requires that your video card gives you the correct screen resolution for your tv. not all displays will work.
If your configuration is 3. the tv is the only resolution that is being pushed and just adjust the resolution til the screen is filled in.
To adjust the screen resolution, right click on the desktop where there isnt an icon and select either Properties (windows xp) or Screen Resolution (windows vista, 7 and 8).
if you have 2 screens press the identify button and it will put a number on each screen. click the appropriate screen and go to the resolution dropdown below. Change, apply and if it doesn't look right, revert and try a different setting. if you try them all and it won't take up the full screen, then the video card can't push the video resolution your monitor wants.
Sep 30, 2014 | Computers & Internet
How do i widen my screen
That's a function of the monitor controls.
Apr 15, 2014 | Dell Dimension 2400 PC Desktop
WIDEN MY DELL MONITOR SCREEN
I am unsure what you need o do. is it changing the resolution to make it fit? If not, then you can widen the screen by the monitor settings on the menu
Mar 16, 2013 | Dell Computers & Internet
How do i widen my screen on my monitor
there might be some adjustment tabs on the monitor if you cant see any run a finger across the underside on the monitor
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 02, 2012 | HP Computers & Internet
Widen border on Toshiba lap top
Widen border on what? A document, if so go into page setup. If you're talking about the whole screen, go into the Desktop under the Control Panel and change the screen resolution.
Mar 30, 2012 | Computers & Internet
To widen border on Toshiba lap top
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.If you cannot change the screen resolution then most likely the incorrect video driver has been installed.
My screen is blank about half an inch on both sides.How do I get the screen to widen on both sides? Thank you
Just set your Display setting horizontal or vertical where you feel need, it is easy and simple.
Good Luck
Feb 04, 2011 | Dell Dimension 2400 PC Desktop
How do i widen my computer screen to fit the whole screen
There are two causes of an unfilled screen her;
1) Either, you don't have drivers installed that the resolution is set to low pixels or pixels that don't match your screen type (Computer does it automatically if the drivers are installed)
OR
2) You need to set or widen the length and height of your desktop screen using the buttons on it - usually on the front. Let me know how it went so i give you plan B...
Dec 05, 2010 | Dell Dimension 2400 PC Desktop
The horizontal monitor size cannot be adjusted. How do I pull the left and right sides to widen the monitor?
inside the monitor you wil find a adjustabel potmeter(screw) in the erea of the flyback transformer.
this is the horizontal voltage adjustment
if you turn it clockwise you wil see that the screen will widen more or less.
Feb 13, 2010 | IBM E74 17" CRT Monitor
ViewSonic VA1930WM LCD Monitor Logo
66 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
