Question about Water Heaters
It doesn't heat enough water & makes noises
I have state censible 510e water heater, that at least 10 years old. It doesn't heat enough water or it doesn't heat at all especially in the morning (5:30 am I have almost cold water). today it started to make noise inside like something was hitting it from the inside, not regularly. What does all that mean? Monika
  • 43,501 Answers
Here is a tip that will help you...
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
heatman101
Posted on Apr 28, 2010
Sounds like a truck
If the heater is more then a few years old the heat exchanger is probably corroded. Air flow from the blower motor can't squeeze thru the exchanger fins and causes loud vibrations. It can sometimes be cleaned but usually requires replacement of the heat exchanger. If you are not familiar you should definitely have a professional sevice the unit. Continued use in its current state can cause many other issues. Be prepared because the heat exchanger is the most expensive part of the heater and the most difficult to replace
Jan 10, 2014 | Water Heaters
Installed but not heating
State point-of-use electric water heater plugs in.
Check that outlet has power.
The water heater must be full of water or elements burn out instantly.
Test the element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Match voltage to water heater:
This electric water heater, like all electric water heaters, will work on 120Volt, 208-240Volt or 3-phase unbalanced.
But wire size and breaker must match element wattage.
If you have outlet, check the wire size and breaker, and check what other devices are drawing power from same circuit, then add up total watts and compare with charts on link below.
http://waterheatertimer.org/Color-codewire.html#water-heater
Oct 20, 2012 | Water Heaters
My water heater makes a loud popping noise. I drained the heater & it stopped for two days but has again started popping. It seems to pop when the hot water is turned on.
Sounds like an old water heater, full of rust at bottom. maybe coming to end of its life. Think new if over 7 years old. Did you replace anode rod? Probably shot also. Good Luck...
Aug 30, 2011 | Whirlpool Water Heaters
Sounds like a squirrel inside water heater
Check your thremostat setting if it is set to highest position it may be causing some of the noise over heating the water and making the noise. And you can put an insulated jacket on it to maybe help with sound.
May 14, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
The noise is inherent in electric hot water heaters. It is the noise that the water makes when it is being heated by electric heating elements. Mineral buildup on the elements can make it worse, so changing the elements can help...but will not totally elimenate the noise. When I install a new tank and turn it on all I have to do is listen to it to see if it is working or not...even brand new will make a sound...it is the sound of hot water... :-)
heatman101
Mar 25, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Noisy Rheem 16 instant hot water heater
About the only device in that heater that could cause the noise you describe is an electrically operated valve that controls water flow. Rheem is a better-than-average company so I would give them a call and describe your problem to them; I'll bet that they will be glad to tell you which part you need and supply it to you.
We had a heat pump system from Rheem that needed only the replacement of one large relay and the outside unit fan motor during more than 25 years of service and is still operating at age 30 in our former home.
Oct 03, 2009 | Rheem 81VP6S/430126 Water Heater
After about an hour the breaker trips on a single element Rheem water heater. 2Meg ohm to ground from the element terminals: 700K between element termianals. theromstat connections to ground infinate. (can...
I would say then the heating element has a resistive short to ground. The 1.98m Ohm reading is high, but not high enough -- should be infinite. I would say replace heating element... And, when you install new one, make sure there is no water leaking thru heating element cavity and ensure area around cavity is clean & "in order".
How old is water heater?
Charlie
Sep 29, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Popping noise from tank - 6G40-36FI
Sounds like water is over heating. (thermostat).Is water real hot.?
Jul 06, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
191 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
