Question about Kenmore 42822 Front Load Washer
Washing cycle keeps stoping after about 5 min from start.
The washing program gets stuck in the same spot. We have to go to drain and spin to bypas/ go around the "stop". The mashine is about 6 years old. I am an electrician if you can give me some hints it be great.
  • 6 more comments
  • jacmycaffe Apr 28, 2010
    Kenmore model 110.42822 203
    Type: 199 700WT-GT 12a 120v 60Hz
    It is Kenmore Front Loader
    Here is more info that you requested. The fault appears to be blinkng letters S and H, They alternate. Unit is also "Beeping". Hope this helps you find solution. (Kenmore front loader Model 110.42822 203)
    Thanks for the test mode instructions, I am away from the washer so I will try running it tomorrow to see what fails in test mode. When the mashine stops, it displays alternating letter S and H and beeps. I will try test mode as I get home and I may have a question tomorrow. Thanks for now.
  • jacmycaffe Apr 30, 2010
    I tried to go to diagnostic mode but after trying your instructions multiple times I couldnt achieve the results. As I select Drain/Spin the displays shows 011 ( time remaining) Then you said press Spin Select button 5 times - I keep pressing Drain Spin 5 times to select no spin ( I don't see "Spin Select" so I assume you mean "Drain/Spin" push button switch?
    My Kenmore 110.42822 203 wash mashine has "Prewash" button and that one I am OK.
    Pls help me get thru this one.
    To answer your question mashine spins ok, lets water in and drains. It just stops after about 5 minutes and blinks "S" then "H" and display cycles like that while mashine beeps and I am unable to open the door. Unless I push drain mode - nothing happens it won't proceed to next step.
  • jacmycaffe May 01, 2010
    Hi, had great leap fwd. With new hint I went to test mode. Mashine goes from the begining until C:03 Hot water inlet valve test and stops there while displaying "F" and "H" . It stays there and doesn't go to next step ( I waited about 5 minutes to see if it moves to C;04, but I guess it stops at the first fault? What do I do next?
  • jacmycaffe May 07, 2010
    Thank you for watching over my shoulder. I had problem with hot water flow - resttricted by solenoid valve being clogged. Flushed and got good flow and self test diagnostics run all the way to the end without stopping at c:03.
    Thanks and most likely I adone with the repair
    President:
  • 1,554 Answers
The washer may have a provision for error codes when a fault occurs. Specify the exact make and model number of the washer for specific and accurate advice. The accuracy of the troubleshooting depends on the amount of information given.
Posted on Apr 28, 2010
  • 8 more comments
  • Jahn27
    Jahn27 Apr 28, 2010
    Is there any flashing code on the Estimated Time Remaining Display, any flashing LED, or a beeping sound when the washer stops.? Does it spin?
  • Jahn27
    Jahn27 Apr 28, 2010
    Activate the diagnostic test mode to check the functions of the washer.
    Close the door then Select Drain/Spin cycle
    with the cycle selector and select No Spin by pressing the Spin Select
    button 5 times. Push the Prewash option button 4 times within 5 seconds. If your washer doesn't have the Prewash option, use Rinse/Hold.
    C:00
    will display indicating that the test mode is entered successfully. If
    unsuccessful, press the Pause/Cancel button then repeat starting the
    sequence.
    Push the Prewash button 2 times to advance to the next
    step of the test. The last step is indicated by C:08. Check for any
    error code after the test.
  • Jahn27
    Jahn27 Apr 28, 2010
    Here are the test steps:
    C:00 - The door is locked to check the door lock system.
    C:01 - The cold water inlet valve is activated to check the flow meter and the cold water inlet valve.
    C:02 - Distribution System is set to Prewash position to check the dispenser motor and the dispenser contact.
    C:03 - The hot water inlet valve is activated.
    C:04 - The basket rotates at wash speed to check the motor and the motor control.
    C:05
    - Heater is switched on and basket rotates at wash speed. The washer
    fills to the minimum level if there's no enough water in the machine.
    C:06 - The drain pump turns on.
    C:07 - The basket rotates counterclockwise from 35 to 90 RPM within 15 seconds.
    C:08 - The basket rotates with maximum speed.
  • Jahn27
    Jahn27 Apr 28, 2010
    Thanks for the information. After it is started, about how long before it stops? Does it wash or spin?
  • Jahn27
    Jahn27 Apr 28, 2010
    Double check the flashing code. I cannot find such error code, it's probably Sud or FH.
  • Jahn27
    Jahn27 Apr 30, 2010
    I mean SPIN SPEED button instead of SPIN SELECT button. My apologies for the mistake. Retry entering the automatic diagnostic mode.
  • Jahn27
    Jahn27 Apr 30, 2010
    Unplug first the washer then plug it again and press Control On button, if there's any, before starting the diagnostic test.
  • Jahn27
    Jahn27 Apr 30, 2010
    Here's the tech sheet for your washer.
  • Jahn27
    Jahn27 May 01, 2010
    The central control unit (CCU) which acts as the "brain" of the machine
    detected that either water is not entering the machine or the pressure
    switch has not tripped 8 minutes after the water inlet valves are
    turned on or after the flow sensor has detected 10.5 gallons of water
    passed through it.
    Verify if there's water inside the machine; if
    there's not, make sure the water supply valves are open, the water fill
    hoses are not plugged or kinked, the screens in the water inlet valves
    are not plugged, and the water inlet valves are working.
    Check the
    drain hose for any leak and for siphoning. Water may drain as the
    washer fills due to siphoning and cause the the error to flash. Please
    indicate if there's water inside the washer or not when the error code
    flashes to determine the specific parts that need to be checked as the
    error code may signify a problem in any of the water system components
    such as the water inlet valves, flow meter, pressure switch, and the central control unit.
  • Jahn27
    Jahn27 May 07, 2010
    It's a pleasure to help you find and solve the problem. Please accept and rate the solution provided. Thanks for using Fixya.
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
My washing machine won't spin when in a wash cycle but will spin on a spin cycle
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
Jun 09, 2015 | Hotpoint WF430 Front Load Washer
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
Bosch classixx washing machine over fills, stops for 5 mins,drains water and stuck on rinse without doing the wash cycle. it spins when spin cycle is manually selected.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 25, 2013 | Bosch Classixx WFL 2066 Front Load Washer
My washer started just find, then have way through the wash it stoped dispensing water and will not drain. Tried spin cycle only, and nothing. Tried unpluging, and still same problem Tried restarting...
all frontloaders have to start the drain pump before any cycle will start ... if there is something stuck in drain pump or hose between bottom of wash tub to pump washer will not spin... check filter pump assymbley and drain pump
Jan 24, 2011 | Frigidaire Washing Machines
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 42822 Front Load Washer Logo
178 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
