Question about Car Audio & Video
I have a 90 ford taurus i installed a stereo ,now i have no turn sigs or flashers ? i have cheked the fuses & flasher all good ,they do come on briefly sometimes ! help , toonage31@yahoo.com
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
If you had to unplug a hazard switch for any reason, check that.
Posted on Apr 28, 2010
Right turn/brake/flashers out bulb is good all fuses good
the flasher is built into the multifuntion switch (Turn sig switch) You have to replace it to replace the flasher
Jun 12, 2010 | 2005 Ford Freestar
How do i put my eectronic flsher in my car
I would suggest that the flasher is either in the fuse box, or in the electronic distribition box (black box near the front driver's side) in the engine compartment under the hood. Unplug old one and install new one with comparable replacement.
Apr 01, 2010 | 1999 Ford Taurus
We have no blinkers or flahers on a 1997 ford taurus and the fuses are good
Ford Taurus/Sable 1996-1999 Repair Guide
Flashers - REPLACEMENT
Check your flashers:
Fig. Fig. 1: Flasher assembly mounting
  1. Disconnect the negative battery cable.
  2. Locate the flasher assembly under the driver's side of the instrument panel and remove the flasher retaining screw.
  3. Detach the flasher from the connector and remove the flasher from the vehicle.
To install:
  1. The installation is the reverse of the removal.
Other details can find in the Ford-Taurus Owners Manual (page 124 and next)
Hope helps with this (remember rated this).
Jan 14, 2010 | 1997 Ford Taurus
Hazard Lights Won't Work on 96 Taurus
FIRST Check for Blown Fuse Then Locate Flasher Units @ Fuse Block to Determine Wiitch one is Hazard Turn On Key Then Turn Syg. Feel Flashers The One you feel Clicking is For Turn The Other IS Flasher Replace this Flasher unit.
  1. Verify the customer's concern by operating the turn signal/hazard flasher lamp to duplicate the condition.
  2. Inspect to determine if one of the electrical concerns apply: VISUAL INSPECTION CHART Electrical
    • Circuitry open/shorted.
    • Fuse junction panel Fuse:
+ 15 (10 A) + 29 (15 A)
  • Damaged multi-function switch.
  • Miniature bulb burned out.
  • Damaged lamp.
  1. If the inspection reveals obvious concern(s) that can be readily identified, service as required.
  2. If the concern(s) remains after the inspection, determine the symptom(s) and go to the Symptom Chart. See: ProceduresSymptom Chart(s)
Jun 01, 2009 | 1996 Ford Taurus
Turn signal and 4- way not working
Installed a new turn signal arm
Apr 15, 2009 | 1996 Ford Taurus
Flashers not working
pull the fuse panel cover and the cover will show you where the correct fuse is.
Does the emergency (four way) flasher system work?
Make sure the four way flashers are OFF , as the turn signal indication lamp system will not work with the four ways ON.
Dec 03, 2008 | 1998 Ford Taurus
1996 Ford Subaru where is the turn signal flasher hidden
The flasher is behind the trim panel under the steering wheel, it is an electronic module.
Oct 20, 2008 | 1996 Ford Taurus
1988 ford Mustang 2.3L
your turn sig switch in the steering column is probably worn out and needs to be replaced, have a steering column specialist come out and fix or go to the dealer.
Jul 29, 2008 | 1987 Ford Mustang
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
