Question about Goldstar WG5000 Air Conditioner
Compressor is not kicking on
The unit has power and both the fans are on, but the compressor will not start up.
    Guru:
  • 1,524 Answers
Bad Run Capacitor.
Posted on Apr 28, 2010
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
3 ton unit compressor dont wnat to start
there is a capacitor connected to the compressor and one connected to the fan ... the capacitors are used to start both (called starting capacitor) ...if its bad then the compressor/fan may buz but not start ..it will kick out once it gets hot .. that thermal cutout will reset when it cools down ... the capacitor may be a dual unit .. that is, two capacitors in one case (one for fan, one for compressor) ... you could have a frozen compressor or bad bearings in the fan but typically its just the capacitor thats bad (make sure the fan turns freely) ... follow wires coming out of the compressor and fan .. some will go to the capacitor ...thats a metal part (usually a rounded rectangular shape about 4 inches) .. the 3 or 4 wires just plug into the capacitor .. replace with the same value (microfarads and voltage) or get an exact replacement using its part number ... mark what wires go where .. make sure power is off befor servicing ..
Jul 25, 2010 | Goodman CLQ36AR49 Air Conditioner
Neither A/C compressor or fan coming on in ouside unit.
The bulge is a telltale sign of a defective capacitor along with the tripped breaker. Replace it and cross your fingers.
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Compressor won't kick off
What happens when started in just fan mode? Sounds like relay stuck.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
Kenmore a/c window unit fan not kicking on with compressor.
Likely a bad motor, when this occurs verify the board is sending voltage to the motor.
May 30, 2017 | Kenmore Heating & Cooling
Compressor kicks in, trips the breaker.
It is a 1977, usually with age the compressor gives out. You should check the power coming into the compressor, going out of the compressor, check the clixon on the compressor make certain the wires are not touching, how long has it been since the capacitor has been changed?
Jun 05, 2009 | Kenmore Heating & Cooling
Goldstar WG5000 Air Conditioner Logo
67 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
