Question about Philips Magnavox DVD+R/+RW Recorder/VCR
Magnavox #MWR20V6 DVD Recorder/4head HI FI Stereo VCR
The VCR will only operates for a few minutes and then shuts down.
I would appreciate any help you can give me
Thanks
Bill
  • 871 Answers
VCR problem... replace the idler.
IDLER - symptoms:
  1. Eats tapes. Capstan pulls tape off the supply reel but the takeup side can't reel it in.
  2. Won't rewind, sometimes intermittent.
  3. Shuts off sometimes.
  4. In early failure stages, while playing, the take-up reel inside the cassette may behave erratically.
  5. When you press stop, the guide rollers retract without pulling in the tape.
THE PROBLEM - worn idler. Older VCRs have an idler that uses a rubber tire. Over the years, a slow chemical reaction occurs on the surface of the tire. This process results in a glazed surface, causing loss of traction. With a dummie cartridge you can see that the idler does engage the reel table, but if you grab the reel table with your hand, you find there is little or no torque. Without traction, the tire only slips against the reel table. If you push the idler into the reel table with your finger, it will work, but only as long as you keep your finger on it. Often all you need to do is replace the tire.
The tire can be easily removed. It's not glued or permanently fastened in any way. A small flatblade screw driver is a big help in removing the old one. In fact, you can turn it inside out and remount it that way. But since there are no treads on the inside wall and the fact the rubber has a lot of years of deterioration on it, you will be lucky to get a few months out of it. But at least you can still use your VCR in the meantime.
Newer VCRs have a gear instead of a tire. Although gears are much more reliable they still have problems. Usually becoming warped or loosing tension. The plastic retaining cap over the spring sometimes cracks. Without sufficient tension, the idler tends to get caught between the reels. This can be easily seen if you have a dummie cartridge. Gear driven idlers are one piece, so replacement involves the entire idler
hope you have grasped what is said here.
thanks for using fixya
Posted on Mar 25, 2008
  • earl norman llanera
    earl norman llanera Mar 25, 2008
    follow up! Always be careful when DIY ok.
    as an added bonus, here is a link for you to further understand what is going on with your VCR. please have the time to read.
    here is the link.
    http://www.fixer.com/osm/top-15a.php
  • 4,889 Answers
Looks like an over heating problem.. This unit is known to have overheat problems and when this happens the protection circuit will turn off the player.. As maklean has suggested have the protection circuit to be inspected by a qualified tech..
    Genius:
  • 1,665 Answers
It's Power supply must be inspected by an authorized tech.
SOURCE:
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
My VCR unit only plays a tape for a few seconds, it stops,turnsoff entire system and ejects tape. I have tried to clean it. Is there a fix for this problem?
If the take up reel is not properly winding the tape the machine will shut down. U need to address that issue to resolve the problem.
Jul 22, 2015 | Magnavox ZV457MG9 DVD Recorder and 4-Head...
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a Magnavox MWR20V6 - have a few things going on, one the power shutting off automatically when i put the vcr on timer and therefore does not record, and 2 vhs tapes that are almost new, gets stuck
Junk it. It's identical to Funai WV20V6. I can't remember exactly what is causing the shutdown. But, I do remember that it says it can't be fixed. Read other posts here at Fixya.
"Funai wv20v6 dvd/vcr player recorder"
Mar 17, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr tape plays for a few seconds then powers off
remove cassette mechanisum and clean all the sensor's
Sep 28, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
MAGNAVOX DVD/VCR RECORDER
I have been using my machine with no problems, until recently. The machine will not stay on more than a few minutes when I try to use it, either watch a tape or tape a show. It starts, then just shuts down. When the machine is turned back on it ejects the tape????
Can you help, please.
Thanks
Sharon
Jul 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox MWR20V6 problem
on my magnavox mwr20v6 i cant record my vhs to dvd i get black screen every time and my DVD are new and I just open my magnavox after a long long time and ecsup for get my VHS record to DVD it is fine I would like to fix this issue :(
Jan 01, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I purchased a Magnavox MWD7006 and need to have it play in Db5.1 KOSS Entertainment system; thus far only plays in stereo; anyone know what I'm missing? I'm using a S-Video cable.
Dec 15, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
240 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
