Question about RCA RCR311B Remote Control
Need to get remote to work tv - RCA RCR311B Remote Control
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 09, 2012 | Televison & Video
My remote isnt working
Regards.
Jan 04, 2012 | RCA F27676BC TV
T.V. remote sensor not working
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
Nov 28, 2011 | Televison & Video
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
May 08, 2011 | LG 32LC7D Television
The remote doesn't work at all
First, if remote doesn't work, try new batteries......
Regards.
Apr 25, 2011 | LG 32LG30 32 in. LCD HDTV
Need code for SV2000 tv/dvd combo & Comcast remote,
Any remote supporting Sylvania TV/DVD combos will work for these tvs. I had a Zenith universal remote working with this TV.
Nov 26, 2009 | One For All URC-4021 Remote Control
Need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Dec 06, 2008 | Directv RC23 Remote Control
I need a code to make my remote work my tv
i have a rca tv and a magnavox universal remote and i need codes to program
Jul 08, 2008 | Televison & Video
RCA RCR311B Remote Control Logo
964 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
