Question about NAD T743 Receiver
Overheat on start up
My NAD T743 is overheating on startup. This started after I left it unplugged for a day and a half. I have tried the reset procedure of "Video 6" and "source up" button. I have tried starting from the auxillary power button in the rear. But the unit goes to "over heat" as soon as it warms up. What to do?
  • Richard Gilpin May 01, 2010
    I went in the other direction and started disconnecting stuff from the back one by one. The problem went away after I removed the patch-cord plugged into the "CD" jacks. That's OK. The combination CD-DVD player is plugged in at the "DVD" jacks. I used the "CD" jacks for an occasional connection to a nearby computer. Now I wonder if there is a problem with the patch-cord or the jacks.
SOURCE: Power on T743
Just had my t753 in bits... sounds like its overheating to me. Check that the fans on the bottom still turn and aren't clogged up with dust. Make sure that it has plenty of ventilation.
hmm, also try unplugging everything and leaving it on and see if it still freezes? ie check you're cabling is ok, there are no shorts from bare speaker wires etc...
Could try resetting it too? (in each case hold the buttons for 5 seconds then release)
- Firmware version: hold video 6 and tone control
- Reset DSP: video6 + tone defeat
- Reset completely: video6 + right source button (this will wipe all settings - hold for 5 seconds, release and then unplug from the wall or turn off with the rear power switch)
Posted on Nov 30, 2008
SOURCE: OVER HEAT
To reset the the T743 hold down the video 6 and the source up buttons for 3 seconds. then power up from the back button
Posted on Sep 13, 2008
SOURCE: turns itself off
NAD Technical Bulletin T743-H2005-06 describes the problem "Unit may shut down, shortly after turn on".  Reason: There is a diode on the standby board that maybe operating intermittently.  Solution: Locate and identify D756 on the standby board.  Change only if the diode is a 1N4148.  Change from a 1N4148 to a 1N4004 or equivalent.
It is located near a transformer and some fuses.
Posted on Oct 29, 2008
SOURCE: NAD 7140
The clicking is the sound of a bad relay. A relay is an electrical switch that opens and closes under the control of another electrical circuit. There is no user solution for this. You'll have to take it to an electronics repair shop (~$150) or dump the whole unit.
Posted on Dec 19, 2008
SOURCE: My NAD T743 will not switch on
Hi, have you checked the power button in the back to see if it got pressed by accident? It's a round button located right under the speaker inputs in the back.
Posted on May 09, 2010
The amplifier has occasionally shut itself off due to overheating for the last 3 years (I've had it since 2005). But now it continuously shuts itself off and simly won' start up anymore. Does it need a...
They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
A heat sink is just a finned heat-conducting device for radiating heat to the air which should be flowing freely through the unit's ventilation holes. It can't break in normal use. But it CAN get clogged with dust reducing its effectiveness.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T743-Receivers-manual/id/8043bh636/t/2/
Page 6
"Choose a location that is well ventilated (with at least several inches to both sides and behind), and that will provide a clear line of sight, within 25 feet/8 meters, between the receiver's front panel and your primary listening/viewing position-this will ensure reliable infrared remote control communications. The T 743 generates a modest amount of heat, but nothing that should trouble adjacent components. It is perfectly possible to stack the T 743 atop other components, but the reverse usually should be avoided. Nonetheless, it is generally preferable that the T 743 stand alone. It is especially important that sufficient ventilation be provided; if you are contemplating locating the T 743 within a cabinet or other furniture, consult your NAD audio/video specialist for advice on providing adequate airflow."
If you're lucky, you haven't finally toasted it. If you have, a hands on tech will need to sniff sround (literally) to find the dead component(s).
Mar 06, 2011 | NAD T743 Receiver
NAD 2100 power amp. Starts OK, after a few minutes, starts to develop a 'hum'. Soon overheats and the cut-out operates. As the problem affects both channels equally, I am guessing the problem is with the...
What part of overheating are you missing here?
Page 7
http://nadelectronics.com/content/100420120946-NAD2100.pdf
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 25, 2011 | NAD Audio Players & Recorders
My NAD T743 will not switch on. I haven't used for a couple of months and it was working just fine before. Now I tried switching it on using both the power button on the amp itself and the remote, to no...
Apr 11, 2010 | NAD T743 Receiver
NAD T743: The digital channels stop working after a short time.
Hmm, sounds similar to my problem. Analog input and FM seems to work but all coax/opto input are dead ( for me there isn't a buzz).
Have you, fredrik648, solved your problem?
Anyone with ideas what to do?
Thanks
///Johan Westerlund.
May 11, 2009 | NAD T743 Receiver
Nad 743 shuts off at -14db vol. Why?
mine got fixed by replacing the front panel PCB with control processor. Only 350€...
Feb 28, 2009 | NAD T743 Receiver
Using NAD t743 with Panasonic DMP-BD55
The reciever you have has 5.1 inputs at the backof it.The only way to get Dolby True HD and DTS HD is to run the 7.1 analog out from the bd55 to the nad. You'll have to leave the 2 rear surround open on the bd55 leaving the remaining 6 connected to the nad. The digital coax and the optical will not transmit the hd data, only the analog out will. Run a hdmi right to your HD tv for picture bypassing your amp. this will workfine and you'll have the audio you want. You,ll have to change the input settings for dvd in your amp to 5.1 to recieve the audio.
Dec 14, 2008 | NAD T743 Receiver
Power on T743
Nov 23, 2008 | NAD T743 Receiver
OVER HEAT
Aug 18, 2008 | NAD T743 Receiver
Turns itself off
Aug 07, 2008 | NAD T743 Receiver
Does not respond to remote control
I have had the T743 for about three years now. The first unit which I got from the local shop was doing exactily like your described after couple of minutes use. Well, I took is back and got a new one covered by the warranty.
Unfortunately I never got any explanation to this problem from my local shop or anywhere else, so I guess the only way is to contact your local shop.
Dec 27, 2007 | NAD T743 Receiver
NAD T743 Receiver Logo
898 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
