Question about Emerson EWL20D6 Television
How do i disconnect my emerson dvd player? it is a combo and it is trying to run but does not work so the motor causes an irritating noise.
  • prettypami Apr 30, 2010
    i took off all the screws that hold the front housing on, but the thing just would not disassemble. it looks like the plastic tab on the bottom is on too tight for it to budge. is there an easier way??
  • 687 Answers
The only way is to open the cover and disconnect the internal power lead on the Low Tension (Voltage) side of the transformer with the power OFF that is.
Posted on Apr 30, 2010
  • Emerson Master
  • 12,061 Answers
I looked everywhere for a free service manual, but couldn't find any. What I would do, is open up the unit, locate the motor, and Cut, the Wire to the motor. That way, nothing else can be affected. Of course, you could try to locate the Incoming Power to said DVD, and simply pull off the power connection,on the DVD's MB. However that MAY, influence something else, which, is why i recommended to snip, the wire on the motor, A: easy to find & do, will not, should not influence anything else If a manual could be found, then as related you could locate the Power input, and disconnect..
Posted on Apr 28, 2010
Emerson VCR/ DVD Player Model # EWD2203 makes clicking noises when I watch dvds
OK, first go through these steps:
(if they doesn't work, then you have to say good bye to the combo.
1.) check if your DVDs aren't scratched (very common)
2.) check if your DVDs aren't dirty (eg. somebody held it in his hands after he ate a juicy marmelade bread)
3.) Try to clean the head (lens) of your DVD player with a cleaning DVD (at least 5 times).
Jul 26, 2014 | Emerson EWD2203 DVD Player/VCR
Emerson EWC20D3 20 in. TV/DVD Combo what is that loud whining noise from the back
What happens in this case is a small transformer or the high voltage transformer vibrate hard enough to make that sound--not loose or bad but can cause the vibration.
I have seen in customer's homes where it was loud enough to chase cats right out of the room even in a large room.
Two ways to deal with this----with the set apart locate the part by ear or even probing with a plastic tool---when you press close to it, the sound will diminish or go away.
Believe it or not (in our shop) once located we use a hot glue gun to take the sound away---
usually if very loud it is the high voltage transformer on the main TV board (see photo of a typical one) not on the black part but on the iron like (it is a different material) core that looks like a U bolt.
it can irritate but poses no danger.
Mar 28, 2012 | Emerson EWC20D3 20 in. TV/DVD Combo
Scrren froze up while watching a DVD
clean the DVD player with a cleaning kit you buy from any eletronics store. If that does not work you need to service this as the optical laser is not functioning when it heats up at the solder joint this would cause artifacts and freezing as you prescribed. So diagnosis dirty optical laser or malfuctioning optical laser at solderjiont.
Sep 23, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Emerson dvd/vcr combo little leaps code
I went to the Little Leaps website and went into customer support and viewed a link that provided additional codes. I have the Emerson dvd player with video cassette recorder EWD2203 and the code 027 which was listed in the additional codes at Little Leaps website worked for me.
Here is that list of additional codes from the Little Leaps website:
018,030,035,005,150,151,043,058,011,147,148,016,004,002,144,007,009,146,013,020,027,133,042,129, and 149.
These codes were listed to try with any players.
Good Luck.
Nov 17, 2008 | Disney DTD1363-CAR 13" TV/DVD
Emerson ewd2203 video/dvd combo
Do you know why the tape was stuck? How did you get it out? On most vcr's there's a mode switch connected to the mechanics of the vcr. If the mode switch isn't in stop position, the unit will try to get it there and shut off if it can't. Bad belts, bad idler wheel, dirty mode switch, mechanical timing off (maybe due to forcing a stuck tape out?)... all these can cause this.
Geno
Feb 27, 2008 | Emerson EWD2203 DVD Player/VCR
TV doesn't read movies .makes weired noises
hi try cleaning your DVD player because theres an eye that reads the disc so if you try to clean your DVD player if its not that then i cant help you
Jan 29, 2008 | Emerson EWC13D4 13 in. TV/DVD Combo
EMERSON DVD PLAYER CLICKING NOISE..DISC ERROR MESSAGE..HELP!!!
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
Jul 24, 2006 | Emerson EWD2203 DVD Player/VCR
Emerson EWL20D6 Television Logo
35 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
