Question about Toshiba Satellite A70-S249 Notebook
How can you replace the socket that the CD drive plugs into on a Toshiba Satellite A70 laptop computer?.
  • wickedwitchn Apr 29, 2010
    Yes, I mean the socket on the motherboard where the cd connects. It appears that the bottom part of the connection is cracked and not making a good connection, therefore the CD doesn't work. Can the socket itself be replaced or do you have to replace the motherboard completely?
    Thank you.
  • zerodown524 May 11, 2010
    The socket meaning the data connection port on the laptop and not the cd drive.
  • Toshiba Master
  • 1,606 Answers
This is going to depend on what exactly you are thinking of as a socket. On the A70 the drive itself plugs into a socket mounted on the mainboard. The case bottom forms a cavity that the drive slides into. The drive itself is held inplace by a single screw.
To replace the mainboard is going to cost about $150 for a replacement board and then labor and shipping if you are not doing this yourself. It requires the laptop be pretty much totally disassembled. This is about a 1.5 hour job. You can do this yourself if you are comfortable doing this sort of thing. There are several pictorial and videos available that shows how to take these apart.
To replace the bottom is not a whole lot less work than the mainboard. You can find these for $25ish on ebay or laptop repair websites.
I have a A70 and as a word of advice keep the cooling system blown out and don't block the inlets. Ie always sit on a hard surface. They will get hot enough to melt the stickers off.
Posted on Apr 28, 2010
  • Dave King
    Dave King Apr 29, 2010
    The socket can be replaced if you have acess to a reflow.rework soldering station as it is a surface mount part. Thats not the hard part, the had bit is going to be finding a replacment. Toshiba boards are mad in China so they use some strange sources which can be a lot of fun tracking down. It may be easier to just find either a dead a70/a75 board and grab the part off of it or just get a new board off of ebay or somewhere else. These are going for $75 and up so it might be the easy way out if you don;t have tools etc to do this.
What if you are missing a CMOS battery on a toshiba A70?
The battery keeps voltage on your bios to keep the date, time and settings... without it the computer will boot up but not as smooth as one with the battery replaced
Oct 15, 2013 | TOSHIBA Satellite A70-S2561 Main battery...
10 beeps ( 3 short pause 4 short pause 3 short) Toshiba satellite a70
The beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM modules and Cmos battery has charge and dust free sockets are clean and dust free and the ram modules are securely seated in some motherboards cmos batteries are soldered in
Test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) SATA make sure they have a secure connection
check your video card for secure dust free socket
and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error
a computer needs power and data to travel through every working device and have an end to function properly
even something as small as a faulty fan lead can cause this problem computer needs all of the data and power to travel through every device and to have an end to be able work properly
hope this helps
Jul 12, 2012 | TOSHIBA Satellite A70-S2561 Main battery...
Toshiba Satellite a70-s256 fan issues
Instead, turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air.
Give your computer a "blow-job", to remove all the dust that has accumulated inside your computer.
The dust has been acting as "insulation", forcing the fans to run faster, and with more noise.
Cooler computer -> quieter computer.
Jan 16, 2010 | Toshiba Satellite A70-S256 PC Notebook
Does the Toshiba Satellite Pro 6000 have a
The Toshiba Satellite pro 6000 doesn't have a built in microphone as far as I can remember but it does have a microphone socket at the front next to the headphone socket. Both sockets are on the bottom left hand side left if looking from the front. The microphone one is the one on the left, if you look closely there are symbols next to each of the sockets, one looks like headphones the other like a microphone.
Hope that helps
Chris
Jul 03, 2009 | Toshiba Satellite Pro 6000 and 6100 14.1...
I have a Toshiba Satellite A70 laptop.
you can try the memory try one stick at a time. also try the laptop with as little components as possible.
remove the dvd drive, hard drive and wifi card and see if it will boot.
then put each one back in at a time and try it to find the culprit
Apr 24, 2009 | Toshiba Satellite A70-S249 Notebook
How can I get driver for Toshiba satellite 1860
Download link for your machine:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=835412&rpn=PSA70U&modelFilter=A70-S249&selCategory=3&selFamily=1073768663&selModel=835412|PSA70U
Mar 23, 2009 | Toshiba Satellite A70-S249 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
Dec 31, 2008 | Toshiba Satellite A75-S211 Notebook
A70 recover disc in A35 Laptop? (Toshiba Satellite)
Recovery disks are model-specific, mainly because they have different devices and drivers. Setup drivers are downloadable, and copied to a CD at an Internet cafe.
May 16, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Cd drive won't close
There must be a small part locking mechanism that broke or lose thread inside your dvd drive. gently open it and you will see it.
Apr 20, 2008 | Toshiba Satellite A70 Notebook
Toshiba Satellite A70-S249 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
