Question about Acer AL2017 20" LCD Monitor
My monitor had sound and someone playing a game turned it off...I assume as know it it not working. It worked with my other computer and I got a new tower is there a way of getting my sound back,
  • zerodown524 May 11, 2010
    Does the taskbar have a circle with a cross through a speaker?
  • 61 Answers
In the lower r/corner there should e an speaker icon you can mute/unmute and raise/lower volume.
If not, go to Start menu to Programs to Accessories to Entertainment to Volume control, you can adjust yu settings!
Posted on Apr 30, 2010
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
My HP W1907 monitor works fine until I try to play The Sims 3 game. I play for several minutes or hours and the monitor shows the message that it is going to sleep and the light on the monitor goes...
Hi there. I had the same problem months ago when I try to play high end games like Sims 3 my monitor goes into power saving mode. I tried to check every possible causes of the problem. It could be that your computer is overheating try to clean your computer and check if your fans still works. Second it could me your power supply malfunctioning, maybe it does not meet the required power to make your game work. Last cause is your video card malfunctioning, what I did is to just buy a new video card and it works.
If you do not have spare power supply or video card you can go to a computer repair shop for them to check the possible problem that causes it to go into power saving mode. It can also save you money before you can buy a new one.
Hope this helps, Have a good day!
Oct 03, 2010 | HP w1907 LCD Monitor
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
Speakers not working
I haven't seen a monitor that needs drivers for the speakers.
Assuming it has a standard 3.5mm plug for sound input from the PC, have you plugged this in between monitor and PC?
The monitor will have a volume control, make sure it's not muted or turned down too far.
Also check the volume control panel on the PC to make sure it's not muted or turned down.
Apr 06, 2010 | Mag Innovision LT776s 17" LCD Monitor
Acer X193w-- input not supported..
This is likely a screen resolution issue.
That monitor has a native resolution of 1440x900 (I used to have one). If the game is feeding the monitor too high a resolution, the monitor can't display it and.....input not supported. So, if the game has a configuration option (without going into the game itself) set the resolution to 800x600 and try to play. If it works, bump up the resolution until it looks acceptable.
Hope this helps!
Aug 21, 2009 | Acer AL1916W 19" LCD Monitor
Apple cinima display problem
have u updated the drivers, i assume u only took the screen in and they linked it up to there macs,
sounds like a driver issue, try an update,
actionman
Feb 26, 2009 | Apple Cinema Display Flat Panel Monitor...
W3107 no signal from computer to monitor
check the requirements of your game who you played maybe your VGA card cannot support the requirements of the game. and also check the resolution maybe it cannot support.
Jan 07, 2009 | E-Machines eMachines Desktop PC
Input not supported
sounds like the drivers might need to be updated for the monitor and the graphics card. Most monitors install with windows drivers, so it could just be the graphics card that needs updating. What is the make and model of your graphics card
Dec 28, 2008 | Acer AL1912B 19" LCD Monitor
My 14" Likom monitor goes blank after installing WIndows XP
I assume your Samsung Magic CGB5607L is CRT monitor (Not LCD).
It could be the problem with "Refresh Rate" the monitor can't handle. Set the lowest resolution with lowest refresh rate. (800x600 @ 60 Hertz). in Display Properties
Nov 16, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Acer AL2017 20" LCD Monitor Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
