Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Our well jet pump kicks in and out continously. My husband replaced the check valve with on success. We have to turn the pump off at the breaker box. What could this be? We can't see a leak.
  • 12,061 Answers
Www.depcopump.com/.../flotec/FP4000,4100,4800_maual.pdf
www.flotecpump.com/pdf/FP313.PDF
have a look at these manuals above, use this to troubleshoot and hopefully repair.
Posted on Apr 28, 2010
Why isn't jet pump pumping?
Your suction line has an air leak, hence no suction , no prime. All fittings have to be perfectly tight and leakfree on intake side.
Oct 18, 2015 | Jet Plumbing
Power trips out when jets are switched on
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Have a sovereign hot springs spa purchased in 2000. When turning the jets on it kicks the breaker. Also, the inside control system is not working anymore. Could our friendly electrician do this easily,...
When spas turn on initially they run through a purge cycle. This when the pump runs for a few minutes to remove any air in the heating system so the heater does not dry fire.
If your system runs through the start up cycle just fine but kicks the breaker when the heater starts then the heating element is bad and needs to be replaced.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Pool & Spa
My water pump when reaches 40psi clicks on and off contineously
Pull the pump and check for blockage holding the foot valve open allowing the pressure to leak past the impellor back in to the water table. Sand --rocks are sucked up during the pump operation and will hold the ball off the seat.
Jan 27, 2013 | Goulds Pumps Goulds 1 Shallow Well Jet...
My pump when reaches 40 psi clicks on and off contineously
check for a slow leak like a toilet valve. leaking tap in the garden or it may be the non-return valve in the unit is not sealing off and allowing the pressure to leak back into the pump so causing it to cycle. Mostly it will require a new unit to fix.
How do i prime a gould jet pump
turn pump on,pour water in the 3/4 plug on the top of pump.feathering the valve so its not open all the way.
Apr 26, 2010 | Jet Flo 04325143A Marine Heavy Duty Water...
Unloader valve releases a lot of air when compressor shuts off and will not let the motor kick in blows breaker
This is usually a problem with the check valve. The unloader valve on your pressure switch is designed to bleed the pressure off the head of the compressor. With a leaking check valve the pressure isn't relieved from the head and the pump can't turn causing the motor to overload and blow the breakers.
To troubleshoot your problem try the following:
Trace the 1/4" line that connects to the unloader back to the tank. You'll find a fitting there. Remove the lines and then the fitting. Sometimes cleaning that valve will alleviate the problem. If not you need to replace the check valve.
Hope that helps.
-under_psi
Mar 18, 2010 | Coleman Powermate 27 Gallon Air Compressor
Diamond shallow well jet pump wont rotate, froze up.
you need to look at the start capacitor, check it with a meter, look at, and spin bearings. make sure they spin free
Jul 25, 2009 | Plumbing
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
62 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
