Question about Samsung DVD-R130 DVD Recorder
Samsung Dvd R130
Hey,
i was watching tv and i rolled over on my remote now it's stuck on SAFE on the display in the Dvd player, i can't change channels or anything, how do i switch this off?
I would appreciate if you could help me out
Thank you
Kev
  • Anonymous Apr 08, 2008
    SAFE appeared on the display for no apparent reason, and essentially froze the unit.
    I unplugged, replugged.
    I tried to reset by holding both channel buttons (always worked before).
    Checked manual - no mention of SAFE indicator.
  • 3 Answers
THE WAY TO GET RID OF THE SAFE IS TO PUSH INFO ON YOUR REMOTE FOR 5 SEC AND WILL BE "SAFE" NO MORE
SERGIO
Posted on May 19, 2008
  • coldcase007 Apr 22, 2011
    Worked for me. Thanks for posting this. Saved the day!!!
Press intro key for 5 seconds
Posted on Apr 01, 2008
  • 504 Answers
You probably rolled over and hit the exact keys to lock the unit. You should check your owner's manual for the unlock combination (on Sonys it is Return, Enter, Power). If you don't have the manual, check Samsung's web site. It should help.
Posted on Mar 24, 2008
Hola como esta quisiera saber como hago para programar mi DVD SAMSUNG R130 ya que me aparece con la palabra SAFE y no me deja hacer ninguna fucion le agradesco de antemano su colaboracion Att: Jorge...
Gracias Jorge Sanabria por darme la oportunidad de responder tu pregunta.
Chequiando el internet me doy cuenta de que el Samsung DVD-R130 DVD Recorder no es un producto que lo recomiendan por clientes .
Esta es la informacion que encontre. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc 3 de 10 compradores no recomiendan este producto. Mi opinion personal es de que si lo puedes regresar eso fuera lo ideal pero si no se puede asmelo saver y buscamos una solucion para este problema.
Si esto soluciona tu problema x favor as grado mi respuesta. gracias
============================ Thank you Jorge Sanabia because you give me the oportunity to answer your question.
Checking the internet I notice that Samsung DVD-R130 DVD Recorder is a product that is not recomended by the customers.
This is the information I found. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc
3/10 customers don't recomend this product.
In my personal opinon is that if you can return it, that will be the ideal but if you can't please let me know to find a solution to this problem.
If this solution solve the problem pleas grade my answer.
Tahnk you
Aug 15, 2010 | Samsung DVD-R130 DVD Recorder
Dvd-r130 write safe on front panel
sounds like child lock has been activated. most likely button on remote control ( look for c.lock, etc) sometimes power button, play button, stop button etc on remote needs to be held to release
good luck
Aug 10, 2010 | Samsung Televison & Video
HOW DO RECORD AND WATCH THE TV AT THE SAME TIME. I HAVE A V5500 MODEL.
program DVD V5500 to record; use TV/VCR button at top, right of remote to change "operational mode" to TV (will display in DVD window) and use TV remote to change stations.
Jan 09, 2010 | Samsung DVD-V5500 DVD Player/VCR
Disc is stuck in the tray - samsung dvd R130
Without knowing more of your specific situation, it sounds like the disc is physically stuck and is blocking the motor mechanisms from ejecting. There should be 1-2 screws on each side & one at the rear of the player to remove the outer casing. When you open it, any obstructions should be obvious. The screws should be easy to figure out with an arrow pointing to them stamped into the medal, kindof looks like: =>
Mar 13, 2009 | Samsung DVD-R130 DVD Recorder
Samsung DVD-R130 will not load dvds, but will play CDs
Hey,
have you tried a lens cleaner? the lens may have gone bad and would need to be replaced. Do you have warranty on the player?
Sep 02, 2008 | Samsung DVD-R130 DVD Recorder
Need region code for samsung R130 (australian)
hey, try going to this address...i went on here the other day and got my dad's dvd player to go to all regions...incredibly easy instructions too...
best of luck!!
Aug 05, 2008 | Samsung DVD-R130 DVD Recorder
Samsung DVD R130
PLEASE TRY TO CLEAN THE LENSE OF THE DVD PLAYER OR REPLACE THE LENSE
Aug 03, 2008 | Samsung DVD-R130 DVD Recorder
Dvdvcr2 displaying SAFE
Hold down the "INFO" button on the remote for 5-10 seconds and this will clear the "SAFE" mode.
Jul 18, 2008 | Samsung DVD-R130 DVD Recorder
Stuck in Safe mode
PRESS INFO BUTTON ON REMOTE FOR 5 SEC AND EVERYTHING WILL BE BACK 2 NORMAL
Apr 01, 2008 | Samsung DVD-R130 DVD Recorder
Remote control freeze
Hi friend have a tech check your remote it could be damage and not transmitting signals to verify that take a radio and tune into AM point the remote it press the button on the remote.you should hear some static noise like putty putty putty constantly if you do not hear that then you could say that your remote is damage.if not then have a tech look at your set the IR could be bad and needs to be replaced.good luck.
Apr 06, 2007 | Samsung DVD-R130 DVD Recorder
Samsung DVD-R130 DVD Recorder Logo
239 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
