Question about GE Nautilus 24" Built-in Dishwasher
Doesn't put water into every cycle
My GE Nautilas doesn't add water into every cycle. It adds water most times, but usually at the first rinse, or even the second wash, it doesn't add water. It just runs as if there is water, but there is no water.
    Problem Solver:
  • 11 Answers
It sounds like the solenoid for your incoming water is going bad.
Posted on Apr 28, 2010
Testimonial: "This remains to be seen. I'll check it out and see if it helps. Thanks"
    Sergeant:
    Champion:
  • 232 Answers
Bad timer,check the triangle shaped lever with steal arm that conected to it ,White in color, It should move up and down when you maually try moveing it,Has a black plunger attached to bottom of it.Located on left side of pump,If it dont move freely it is jamed and melted in place,Because the timer stayed to long on that spot,when the timer finally did move the damage was done,That plunger controls the water leaveing the machine and broke in the open position,thus the water drains when its not supose to ,The timer and plunger are over a 100$ just for the parts,It would be better to replace unit,Check the condition of the dish rack,Is the plastic coating bubling with rust here and there? That is a sign of age 7-8 years old. This is the EXACT proplem I had with mine.
Posted on May 15, 2010
My washer does not spin after the wash cycle . model ge gcwp1000ww
It sounds to me like the timer could be defective. Thanks
May 02, 2016 | GE Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Put dish detergent in rinse agent dispenser by accident
Hello and welcome to Fixya.
Aside from physically removing the dispenser assembly ( which would be quite involved and include taking the door panel off ) you should be able to "nuetralize" the dish"soap" by adding as much "white vinegar" as possible into the same location as the soap...the jet dry reservoir.
In fact you may have to try this several times, but you could also try pouring straight water into the reservoir, but that will take some time since it is "soap" as opposed to detergent, hence needing a lot of water to de-lute it to much of a degree.
I'd go with the "white vinegar" and repeat that several times through a "rinse & hold" cycle. ( do not add any dishes or cutlery...run it empty )
You can also add a couple of tablespoons of "vegatable oil" directly into the bottom of the dishwasher and some of your regular "detergent" before starting the "rinse & hold" cycle. This will give the soap something to react with and the "detergent" will also help "neutralize" the soap,,,hopefully breaking it down as a result.
To answer the second part of your post...
The effect is going to be oversudsing in the rinse cycle since this is when the jet dry/rinse agent is dispensed in the cycle. So what I'm hoping to accomplish with these suggestion's is to minimize the oversudsing or prevent it all together until the reservoir is "purged" of soap.
Let me know how you make out. It usually works in the cases I've had...eventually. I've seen plenty as you are not the first nor will you be the last...we all screw up, that's life ;o)
Good luck.
macmarkus :)
Jun 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Can I reprogram a front load GE washer so I can add a drain and spin cycle that this machine does not have?.Sometimes my clothes come out too wet and it would be nice to spin and drain them again without...
just add another drain and spin cycle and start it up again with the completion of the first cycle. Washing some items like sleeping bags takes forever because they are so darned absorbent and hold more water than a tiger's sieve of a bladder. Another drain and spin cycle should solve the problem.
Apr 20, 2010 | GE WBVH6240F Front Load Washer
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Adding liquid to rinse cycle
on your h-3 the soap disp tray will allow you the add powder ,liquid, bleach, or fabric softner at the time you put soap in disp then the water valve will dispence at proper times in the wash cyc you don't have to stop the wash cyc
Aug 26, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Stiff clothes in my GE front load washer
Add two cups of white vinegar to the tub and run the hottest and longest cycle. this will clean out your machine thoroughly.
After that add one cup of white vinegar to the wash to prevent stiffness
Aug 05, 2009 | GE WSXH208A Front Load Washer
GE Nautilus 24" Built-in Dishwasher Logo
353 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
