I suggest you contact Webroot support supplying your registration. Although it is often difficult to entirely remove Webroot without using special tools from the Webroot site, I am uncertain what might remain of the prior installation and indeed any installation file and installation key. I would have at my disposal and email confirmation you received when installing the product. Use your email search capability. I take it you currently are without antiviral protection and suggest you limit your use until you get your installation back. Of course, you could install something else until then but then that would have to be disabled and removed before you reinstalled Webroot. You might opt to call them on the phone. I don't know if your version is one provided via Spectrum cable services or not but if it is, that might be another route to reinstallation. https://www.webroot.com/us/en/support
Webroot:
This solution addresses Spy Sweeper 6.1 and Webroot 2011 (version 7.0)
The Webroot Client Service must be running on your computer in order for Webroot software updates to function. If your updates are failing, follow the steps below to make sure the Client Service is started on your computer.
Follow the instructions for your operating system. For Windows XP:
Click the Start button, then click Run. The Run box opens.
In the Run box type services.msc and press OK. The Services window opens.
For Windows Vista or 7:
Click or the Start button.
Type services.msc in the Start Search box and press the enter key. The Services window opens.
In the Services window, scroll down and locate Webroot Client Service.
Right-click on the entry for Webroot Client Service and choose Properties from the menu that appears. The Properties box for the service will open.
In this window, locate the Startup type. If it is set to Disabled, use the drop-down menu to change the setting to Automatic and click OK.
IT IS DUE TO YOUR SOFTWARE PROPERLY INSTALLED 1)REINSTALL THIS GO TO CONTROL PANEL>ADD OR REMOVE SOFTWARES>SELECT WEBROOT ANTIVIRUS>REMOVE 2)THEN INSTALL A FRESH COPY
i have to instal the latest version of weboort .i live in iran and i must bye the weboort or nortun softver by ATM card. please help me . me email is : [email protected]
Though Webroot 6.1 Antivirus works fine on Windows 7, but its Spyweeper (anti spywear), is not seems to be compatible with Windows 7.
You can look for the version of webrrot that is fully compatible with windows 7.
OR
You can go to the free versions of Antivirus availables for Windows 7 (as AVG Free).
