Question about Westinghouse Refrigerators
I have a freezer GVT57AA my dog pulled all the wires out of the back would you have a wireing diagram for it as my son can fix it if he knows where they go.Do you want the dog ? Cheers Jennette
  • flea47 Apr 29, 2010
    we have a upright westinghouse freezer model number GVT57AA dog has chewed wires req
    Genius:
  • 1,040 Answers
Dear Flea,
Following link may help you...
http://www.scribd.com/doc/7599546/HMC150-HMC210-Service-Manual
Posted on Apr 29, 2010
  • 4,924 Answers
Http://www.scribd.com/doc/7599546/HMC150-HMC210-Service-Manual
under my searces this that you showed on the page is the model number ..the actual freezer came under the name Homemaker chest freezer (HMC210...) so this is a service manual ..and includes a wiring diagram...anyway it is a simple 3 wire job ..and if he takes a looc and measure the wires from the plug to see the ground and the null ...it will be easy cause the rest is shown on the manual...(you can even download it ...and print ..its easier ..)
Have a great day ..
Posted on Apr 28, 2010
  • Catalin Turcu
    Catalin Turcu Apr 29, 2010
    did you looked into teh manual?? it is the same name..for the model..but the product name is this one..
1997 Big Dog Vintage Classic at Sturgis, SD this weekend, just quit ! He (Art/husband) is out there looking for the problem..12 volt from battery to turn on switch Nothing after that In linefuse loca
Hi, Deborah and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter control circuit, relay, or solenoid faulty.
11. Main fuse or circuit breaker may be blown or faulty.
12. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
13. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
What to do When Your Motorcycle Won Start
TROUBLE SHOOTING
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
Big Dog manual 2005 all models pdf
Aug 15, 2016 | Motorcycles
Wiring diagram
The wiring diagram should show the proper position of the wires. BE SURE you follow it exactly, and keep son away from machine.
Dec 25, 2013 | Candy CDC266 Dryer
Have a rule 1800 Pump and my dog ate the cord
so cut repair and tape and fix if its near water side use silicon make sure dosent hit water
Jul 22, 2012 | Rule 1800 H53SP-24 Swimming Pool Cover...
Maytag ice dispenser wiring diagram model MSD2456GEB
apc...appliance parts center has a good web site that might get you a wiring diagram. or your local appliance supply store might.
Jan 09, 2008 | Maytag MFI2568AE Side by Side French Door...
PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Dec 09, 2007 | Sony PS2 Dual Shock 2 Controller...
Refrigerators Logo
138 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
