Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet dryer wont heat - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 27, 2010
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: no heat in whirlpool duet dryer replaced the
You have this listed under "Front Load Washer" and don't explain which type of of dryer you have (Gas or Electric). I'm assuming this is an ELECTRIC dryer, since you mentioned a thermistor. The following link will explain how to troubleshoot your dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The symptoms of a dryer no heat problem are, the dryer drum will still spin, the blower fan runs, and all indicators function, but the dryer does no heat. If this is the problem you are encountering, then the link I provided for you should help you find your cause.
The first step to troubleshooting this problem is to check the voltage at the wall receptacle across the two hot leads (the two large slots in the receptacle - each leg to neutral reads 110-120VAC). A reading across the two hot leads should yield 220-224 VAC. If the voltage is incorrect, this can cause the heating circuits to fail, but allow everything else to work. I have seen where one leg of the 220VAC circuit is tripped or not working at all and causes the wall receptacle to read 1/2 the normal voltage that is required. This could be a problem with the circuit breaker panel or wiring in the wall receptacle. The heating circuits require 220VAC to operate, while the controls and drive motor only use 110-120VAC. If the voltage is correct at the wall, check the voltage at the terminal block in the back of the dryer. This is where the power cord attaches. If the voltage is correct at the terminal block, the problem is in the heating circuits. If the voltage is not correct at the terminal block, you may have a bad power cord.
NOTE: Please ensure you UNPLUG the dryer when replacing any internal components. Dangerous voltages are still present with the unit turned off.
Now...what controls the heating circuit in a Whirlpool manufactured dryer is the Thermal Cut-Out (TCO), the Hi-Limit Thermostat and the Heating Element. I'm assuming you replaced the TCO(?). If you did, it is recommended that you replace the TCO along with the Hi-Limit Thermostat. Failure to do so can result in premature failure of components you may have already replaced.
The link I provided explains all this. Please read through the information I provided and let me know if you have questions. If you require further assistance, please let me know before you rate the solution. I hope this helps you resolve your problem.
Posted on Feb 27, 2009
Whirlpool duet dryer wont heat model wed8300sw1
check for 220 volts at dryer it will not heat on only halfe breaker, check heater for continuity and all the thermostats and sensors
May 07, 2014 | Whirlpool Dryers
Why my whirlpool duet dryer wont heat model wed8300sw1
Are the thermal fuses ok? If you're in the back of the machine clean out all the oose, lint, fluff or whatever that causes the heat build up.
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
Whirlpool duet dryer goes to sensing..but wont turn on
The control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box. Here is the part to order.
Nov 26, 2012 | Whirlpool Dryers
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
My dryer wont heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet GHW9150P Front Load Washer Logo
283 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
