Question about Canon ZR45MC Mini DV Digital Camcorder
Canon zr45mc chews tapes and cleaner cassette.
Canon zr45mc mini dv chews tapes and cleaner cassette. what can i do.
  • Canon Master
  • 12,061 Answers
This happens because the "Pinch Rollers" are faulty. They will most likely have to be replaced. The ONLY thing that can be done, due to the delicate and complex nature of any DVR, they MUST be returned to a Canon, authorised, service center. Then ask for a "Quote" before proceeding with any repair.
Posted on Apr 28, 2010
How can i get the Software for my Canon ZR45MC Mini DV Digital Camcorder
You can download the drivers and software for your model directly from the Canon website.
Canon Support Drivers ZR45MC
Apr 26, 2014 | Canon ZR45MC Mini DV Digital Camcorder
Cassette will not fully eject open to remove tape and will not play the tape
if you cant pull it off with a pencil or something small.. you can try with a screw driver and lots of patience to open the tape bay...
Dec 29, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Jul 09, 2011 | Canon XL2 Mini DV Digital Camcorder
My canon zr45mc will sometimes not rewind mini dv tapes and an "eject cassette" message will appear over and over - sometimes my tapes have been eaten. I thought it needed a cleaning so I bought one of...
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 13, 2010 | Canon ZR45MC Mini DV Digital Camcorder
Hi; I keep getting dirty heads message - I run it through with a cassette head cleaner and even try to clean manually with a cotton bud and cassette tape cleaning solution, but after about 20 mins...
Have you changed brands of mini-DV tape? Some are poor and flake off or have a bad binder that clogs up the head. Sony and Panasonic fought it out for years as to whose emulsion binder would win out. Try using a new Canon-approved tape and see if it works. If even that clogs up, sounds like a trip to the shop is necessary.
Mar 22, 2010 | Canon XL1S Mini DV Digital Camcorder
Camcorder chews up tape
clean the heads and rollers with cotton swab dipped in rubbing alcohol
Jan 06, 2010 | Canon MV30i Mini DV Digital Camcorder
Canon ZR45MC Mini DV Digital... Problem
THE TAPE TRANSPORT IS OUTTA BALANCE. THESE GO ON TACKS AND IT IS OFF ONE.. VERY EXPENSIVE. AND VERY HARD TO DO. I AM SORRY
Jan 08, 2008 | Canon ZR45MC Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Problem
I have a Canon4.gif ZR 10 And it does say remove cassette often and recently it eat the tape and destroyed our recordings.
Does this have something to do was the round small battery1.gif in the front part of the camcorder?
Is this a consumer complaint I feel uncomfortable because we have alot of Cassettes recorded and we are afraid to play them because it might chew them up.
There is a mini cassette player2.gif that can play the cassetes ????
Need Help!!!! What am I going to do ??? PNicioli@sbcglobal.net
Sep 24, 2007 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR45MC Mini DV Digital Camcorder Logo
304 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
