Question about Microsoft Xbox 360 Console
Please help my this problem
My xbox 360 is freezing up off and on and the wireless controler is blinking and there is new batteries?
    Sergeant:
    Champion:
  • 427 Answers
For the console, you need to send it back to microsoft for repair before it gets any worse. With the wireless controller, press the grey button on the console until the rings start to blink. Then press the button on the top of the controller until they blink. Wait about 15 seconds and both displays should show a controller in slot 1.
Posted on Mar 26, 2008
I bought another Xbox 360 a few months ago, and for some reason, the wireless controllers take a couple minutes to connect. This happens for both my old controller and new controller, even if they're...
First Check the batteries ,I'm sure you did this all ready.
Second is the RF module AKA ring of lights has a weak transceiver.
This module is simple to replace affter the removl of the case and
three screws on the module itself . Then just plug and play with the
new module . They cost around 10.00-20.00 from many suppliers.
If you have any question feel free to ask.
Rob
Aug 30, 2010 | Microsoft Xbox 360 Console
Xbox 360 controller not working, all 4 lights are blinking.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console:
First, Press and hold down the Guide Button on the wireless controller until it turns on.
Second, Press and release the power button to turn the console on.
Third, Press and release the connect button on the console.
Fourth, Press and release the connect button on the controller.
Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
Jun 06, 2010 | Microsoft Xbox 360 Controller
Keeps saying connect controller,this is a new xbox elite
the problom is your controller , bring it back 2 the shop were u bought it 4 a replacement 1 ,. u can also open it up and fix it yourself but if u dont know how , i wouldnt advise it.
Jan 13, 2010 | Microsoft Xbox 360 Wireless Controller
I just bought a second wireless controller for the 360 Xbox and it blinks continuously with new batteries
did u program it to your 360? if not there is a button on teh top of the controller and on the xbox. they both are a circle button with "radio waves" comming off of them. press both to program it. good luck
Nov 14, 2009 | Microsoft Xbox 360 Controller
Xbox 360 wireless controllers won't work
Try this:
hook them up using the play-and-charge usb cable
Then, disconnect the cable.
they should stay synchronized and worked fine after that.
Jun 16, 2009 | Microsoft Xbox 360 Controller
Wireless controller
press the little buton on the controller and the xbox and it should register
Apr 26, 2009 | Microsoft Guitar Hero: Aerosmith with...
My new *WIRED* Xbox 360 Controller just blinks!!! *HELP*
Wireless:Mostlikey a battery issue or sync issue..
Wired:mostlikey a bad cable..
Wireless with cable:mostlikey a battery or sync issue or cable..
Unknown fact. Controller wires are ment to fail as to make more profits.. How you might ask.. if you have a old wire try stripping off the plastic and the fibermesh wire protecting that four wires are presnt a white and green wires which are for sync and control, and black and red for + and - power imput/output for charging/powering the controler.. What microsoft dosent want you to know is the black and red wires they make 2cm shorter then the green and white.(Note: This has been proven through over 45 wire checks over the past year.)
This causes the wires to rather break over a time through any number of ways the wires handled.. or to burn out through a short in the wires.. most of the time frying your controller in the process. Only solution to extend wire lifetime: Hang the wire strait in a vertical line off of something for example a wall or door.. the usb plug is fine but the problem area is between the "knot" and controller mount on the opposite end of the wire. solution #2: Dont buy wires.. battery packs and battery charge stations are cheaper in the end. "Spend money to save money"
Dec 27, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
