Question about LG enV VX9900 Cellular Phone
Water damage phone was dropped in water on Monday. Took battery out and dried everything with towel. Left battery out and phone open to air dry. Monday afternoon tried to start phone and it would come on and go right back off. Took battery out again and let it dry until Tuesday and when I tried Tuesday to turn phone on I got nothing. HELP PLEASE!!!!
  • LG Master
  • 12,061 Answers
I am sorry but whenever any modern day electronic equipment is exposed to water, especially if it was on. Then it will be a total loss. You see there is an instantaneous, chemical reaction, as soon as the water and the electronics mix. Current tracks, where it is NOT meant to be, and causes catastrophic damage, and no amount of "Drying out" will ever do anything, as the damage has already been done. You will have to get a new phone, it is as simple as that sorry.
Posted on Apr 28, 2010
I have one maxwest cellphone it's damaged by water, can it fix it?
Open the phone and remove the battery. Dab all internal surfaces with paper towel to remove as much moister as possible. Then use a hair dryer on medium heat to gently dry the phone completely. Make sure the battery is dry as well. Leave the phone open for a further half hour after drying and then put the battery back in and close the case. Switch on the phone, good luck.
Dec 30, 2014 | Cell Phones
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
Phone fell in water
If it's at the point where the screen isn't working properly, it's dead. If you have some kind of extended warranty, it may cover it, but there's no real way to bring it back from being water damaged, unfortunately.
Jan 25, 2014 | Samsung Galaxy S GTI9000 Smartphone
SonyEricsson T707 was dropped into water. On recovery (2mins ) later stripped outer covers off and removed battery and sim card. Used hairdryer on unit for about 20mins. Can you suggest anything else I can...
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, but fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one so as not to risk it leaking battery acid in the future.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in water that isn’t pure such as a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours. Unless you have insurance for your cell phone which covers water damage, there is no point in sending it to the manufacture with the hope that they will replace it under warranty. If you drop your cell phone in water, the technicians will be able to tell immediately due to moisture sensitive stickers that are contained inside almost all cell phones. The best thing to do is to try the tips mentioned above and repair it yourself.
Jan 03, 2010 | Sony Ericsson T707 Cell Phone
My samsung impression dropped in water and touch screen broke
I also dropped my Samsung Impression in the toilet, I immediately took the phone took the protective case off, took the battery cover off, and took the battery and my SIM card out and towel dried it as best as I could. Then I sat it on the floor next to my fan and let it dry until I got to my grandparents a little while later and I put it in a bowl of rice, completely covered the phone and battery with rice and left it sit overnight in the rice and all of the next day, so far i've had it on about 20 minutes and have had no problems with it so far, another solution is to sit it in the sun, to further dry it out. Water damage will void warranties on your phone and battery and your provider will know instantly if the damage was water related when they take your battery cover off, there is a small square sticker that when dry and hasn't touched water should be white, but as soon as it comes into contact with water it turns red, there is also one of these stickers on the battery. My stickers were red and after sitting in the rice they look like they got lighter in color considerably, I don't know if that is really possible but appearance wise it looks that way. I hope this helps anyone who has had this problem. Good Luck!
Nov 15, 2009 | Samsung SGH-A877 Impression Cell Phone
Got water damage and wont turn on
I dropped my phone in the toilet and surprisingly it still works. First I took the battery off and dried the phone and battery as much as I could. Then I took my blow dryer and a towel where I folded the towel in half and positioned the phone and the blow dryer under the towel and left it going for about an hour. The next day I took the phone and sat it in the sun until the inside moisture was gone. Then I charged it my phone has been working fine ever since and that was nearly two months ago.
Oct 05, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I droped my voyager in water
HI,
PLEASE USE HAIR DRYER TO DRY IT AND DONT CHARGE OR SWITCH IT ON FOR A DAY....................................
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG VOYAGER VX10000 Cellular Phone
Palm Centro PDA (Pink)
You will probably have to open it back up an clean the contacts with a qtip (or tiny piece of sponge) and alchohol. Let dry overnight.
Mar 09, 2009 | Sprint Palm Centro Smartphone
Drop my phone in water
Take the battery out immediately, dry everything that you can with a towel. Let it stand for a few days to dry out inside before trying to turn it back on or you will fry it out. T mobile will not do anything to help you...
Feb 14, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Nokia E71 with water damage
I dropped my Nokia E71 from two storeys high onto carpark below and can't get it to switch on and power up at all .... how can I retrieve all my numbers and other data that was stored on the phone ? ....
Nov 27, 2008 | Nokia E71 Smartphone
LG enV VX9900 Cellular Phone Logo
145 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
