Question about Garden
Have a toro personal pace 190cc lawnmower and need to change the oil...where is the drain located????
  • 54 Answers
The drain should be under the mower above the blade, it's usually a square head plug.
Posted on Apr 28, 2010
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Toro personal pace mower will not stay started?
If ir starts and runs for only a few seconds it's a dirty carb/bad gas. Drain the fuel system and use FRESH gas; change out your fuel supply monthly to avoid "phase separation" issues. If it runs for several minutes and then dies it is possibly a sticking valve. Do a compression check cold and after it stalls to confirm. Hope this helps
Mar 08, 2015 | Toro 20372 Recycler Personal Pace...
Toro personal pace 20372 starts, runs for 45 minutes then dies
Possible fuel blockage,or ignition source getting hot,electronic CDI unit ,check for spark at the plug when it stops.
Jul 21, 2014 | Toro 20372 Recycler Personal Pace...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
Where's the fuel filter located on my personal
most push mowers only use a screen in the bottom of the fuel tank
Apr 08, 2012 | Toro Garden
How do I change the oil on my Toro Personal Pace mower? Do I need to remove some cover?
The oil drain plug should be under the deck. You probably have a bracket in the way that you need to remove. Once you remove the bracket you should be able to access the drain plug. Piece of advice do not cross thread the drain plug and do not over tighten it. You should only turn the drain plug 1/2 a wrench turn above finger tight.
Jun 15, 2011 | Toro Power Lawn Mower
Change oil in TORO GTS personal pace
warm engine remove dipstick place drain pan on floor tip mower on side so dipstick tube is over pan
Aug 14, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
388 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
