Question about Car Audio & Video
I have a cda-9825 alpine head unit that turns off my amp to my subs only on the tuner source. i belive that i have it all wired correctly. i only have this problem with the tuner the cd and aux sources work fine. my amp isnt going into safe mode it seems to just turn off completly.
  • 2 more comments
  • jadedogy Apr 28, 2010
    no the remote on for the amp is connected to the blue with a white stripped wire and i belive if i did that then it wouldnt work at all instead of just not the tuner
  • jadedogy Apr 29, 2010
    the amp turns off when i do both.when the head unit is on a cd the amp works fine then i press the button to change it to the tuner and it turns off. when i just turn on the car and it is on the tuner the amp turns on for a split second then quickly shuts off agin but then i change the source to the cd again and it turns and stays back on.
    i found what was causeing the problem it was indeed a very hiddin setting that for some reson would turn of my amp thank you for the advice.
  • jadedogy Apr 30, 2010
    yea i dont even think it was that setting cuz i tryed that and it turned off all signal from the deck like front and rear as well as the sub but what was hapining was only the sub amp wounds turn off and the speakers would still play idk what was wrong for sure.
  • 15,935 Answers
Is the radio shutting down?
Remove the antenna connector and re-try.
Thanks!
Posted on Apr 28, 2010
  • 1 more comment
  • blueextc3221
    blueextc3221 Apr 29, 2010
    no - not the remote turn on wire - im talking behind the radio - the antenna plug.
    Thanks!!
  • blueextc3221
    remove the faceplate and press the reset button too.
  • blueextc3221
    as there may be a setting that got turned off or on by accident.
    CLICK HERE for a copy of the user and install manual if you dont have it.
    ALSO - be sure the pink/black MUTE wire is terminated - and not touching bare wire behind the radio.
    Thanks
    Guru:
  • 416 Answers
You didn't mistakenly connect the Amp remote line to the head units power antenna line (Blue) did you? You should be connected to the Blue/White wire for the amp remote line... Just a thought.
  • 1 more comment
  • Adam Halfhill
    Adam Halfhill Apr 28, 2010
    I had a friend who used the power ant line... it is -12v switched. Worked for a while, then knocked his amp out. You need to prob that amp remote line (use a prob light or a volt meter)... to see if it is turning off when you switch to the tuner. I suspect it is. Also, does this happen when you have the head unit on and switch to Tuner or does this happen when you turn the head unit on and you are already on the Tuner source?. If you are out of warranty and just need a solution, you can use the Power Ant line through a relay to create a secondary Remote Amp line. If this is something you want to do, I will put together a diagram for you, let me know.
  • Adam Halfhill
    Adam Halfhill Apr 29, 2010
    Well, I hope you find a solution that makes your head unit work correctly... If you don't... This should be a working solution to get around the problem. I hate Radio Shack's part selection, but this should be an easy part to work with:
    Power Antenna is a switched ground, turns relay on, sends new 12+ line to amp. I've seen the Radio Shack guys solder for the customer... you may be able to get them to attach the wires for you... you'll then just need to splice them in to the wire harness.
  • Adam Halfhill
    Cool, glad it worked out for you. I did see in the manual that you could shut off the internal amp to improve clarity when you are using external amps... never would have thought they broke things down THAT far. Best wishes.
Alpine CDA-9885 has no sound to rear speakers when playing a CD. Works OK when in tuner mode?? What up??
Are you running your rear speaker through an amplifier? If so, you are probably using the blue wire (power antenna remote turn on) instead of the blue/white wire (amp remote turn on). The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
Jul 10, 2012 | Alpine CDA-9855 CD Player
Alpine CDA-9831 No Sound From CD's? My Alpine 9831 has always worked fine on the "Tuner" setting in my stock 3 series BMW. But recently I put a CD in for the 1st time and the head unit shows...
Are you using an amplifier? If so make sure you are using the blue/white wire to turn your amp on. The blue wire is power antenna turn on and turns off when leaving tuner mode.
Jun 28, 2011 | Alpine CDA-9831 CD Player
My alpine cda9885 plays my subs when the tuner setting is on but nothing else, The amp turns off when I switch between the settings and doesn't turn on until on the tuner.
sounds like you have the antenna remote wire (blue) instead of the amp remote wire (blue/white stripe) turning the amp on. the antenna remote turns off when the radio is switched to cd mode.
Sep 08, 2010 | Alpine CDA-9885 CD Player
Amp shuts off when trying to play cd
it sounds like you have the amp hooked up to the power antenna lead instead of the amp remote lead. should be two blue wires.
Jul 29, 2009 | Car Audio & Video
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Volume problem with the AUX input using iPod
Do you have the ipod turned up too? Whats happening is the alpine is getting to low of a foltage signal.
Jul 30, 2008 | Alpine CDA-9825 CD Player
Alpine cda-9811 is not accepting amp as external amplifier?
The signal should go from the head unit to the amp to the subs. Someone must not have wired the subs correctly through the amp, or amp to the cd player..
Jul 08, 2008 | Alpine CDA-9811 CD Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
No remote on VDO CD 139 CD player
If the head unit does not have a 12v switched output you could connect it to the cars ignition which means that the amp will switch on when you turn the ignition on and it won't drain the power when you switch off
Nov 19, 2007 | Alpine CDA-9885 CD Player
Sub cuts out when I switch to CD player?
It shuts off because the remote turn-on wire to the amplifier is connected to the power antenna wire behind your head unit. The power antenna wire is only activated when the tuner is selected. You need to switch the remote wire to the blue/white wire from the head unit (currently you're using the blue wire). This is the true remote output, and will activate the amp whenever the head unit is powered on.
Jul 06, 2007 | Alpine CDA-9885 CD Player
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
