Question about SanDisk Sansa m250 MP3 Player
Drivers of sandisk sansa c250
I need the sandisk sansa mp3 c250drivers
My Sansa m250 is installed as USB Mass Storage Device, without a name and has an error "This device cannot start. (Code 10)". Bottom line, it cannot be used. I tried reinstalling it's driver using the "Select" option and it did not help.
It has nothing to do with the drivers. In fact, this player doesn't even need a driver, it should be recognized by the system as an usb stick. The only solution I could find for mine was to force it into USB 1.1 mode. Go to Settings/USB and set it to MSC instead of Autodetect. Good luck !
Posted on Mar 25, 2008
  • 758 Answers
Just follow the link below..Select your model number from the list
http://www.sandisk.com/DriverDownload/index.asp
Please rate accordingly
Thank you
Computerrep
Posted on Mar 24, 2008
I need SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048) software.....
You can download the driver from the manufactuer's web site at http://www.sansa.com
Mar 14, 2010 | SanDisk Sansa m250 MP3 Player
I have a SanDisk Sansa m250 MP3 player , when I plug the USB
it most likely dosent work on vista due to its age and or sansa never made a driver for vista. try sansa suport and look for drivers and downloads. there might be a driver there
Jun 23, 2009 | SanDisk Sansa m250 MP3 Player
Sandisk sansa m250 not working properly
try upgrading the firmware as follows:
Before installing the player must be in MSC (Mass Storage Class) mode to run the firmware.All files will be deleted. Backup your files.
(To switch modes, Go to Menu > Settings > USB > The two options are MSC and AUTO DETECT (MTP) : select MSC)
Installation Instructions:
1. Download and run firmware from: http://www.sandisk.com/Retail/Default.aspx?CatID=1326
2. Follow instructions in installation.
Hope that helps!
Jun 20, 2008 | SanDisk Sansa m250 MP3 Player
I WANT TO DOWNLOAD SANSA M250 SOFTWARE
What version of windows are you using, did it install by itself without any troubles? It should show up in windows media player in sync or transfer to device.
Jun 01, 2008 | SanDisk Sansa m250 MP3 Player
Firmware & Sansa m250
ok go to my music on the start menu then you should have all your music there just copy and paste to mp3 or mp4 u can do this by going to my computer and see the name of mp3 or it will say under local hadrive mass storage ddevice if you need any more help contact me at id.nightclub@hotmail.com good luck!!
Dec 30, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Solution:
1. Open the start menu and right click on My Computer 2. Click on properties 3. Locate and click on the "Hardware" Tab of the system properties window that pops up 4. Find the button that says "Device Manager" 5. When you do this, another window will pop up with a list of all of the hardware installed inside of your computer, you should see the Sansa Express somewhere in this list with the yellow exclamation mark. 6. Right-Click on the Sansa Express and click on "Update Driver" 7. When the next window opens up, instead of allowing it to search automatically, click on "Install from a list or a specific location (Advanced)" and click next 8. On the next window, click on the last option "Don't search, I will choose the driver to install" and click next 9. When I did this, it had two options listed. MTP Device and USB Mass Storage Device. If you see these options highlight the USB Mass Storage Device and click next. It should install Immediately!! I sincerely hope this helps anyone, I searched and searched on line for an answer, and I couldn't come up with anything. I fiddled around with it for a long time.
Try it... kiran.venkatesh@yahoo.com
Dec 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa - sandisk m250 troubleshooting
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
M250 sandisk
Dec 13, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
377 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
