Question about Frigidaire PLD4375RFC Dishwasher
Cl error code (door)
I am getting a "cl" error code. I have replaced the latch mechanism, but still getting the error code. Not sure what else to check (electrical?).
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You are right Error CL means door is open or door switch is open. However, replacing a door latch should have resolved this if not then you have to check the door switch if that’s making contact inside, if its not making contact then you have to replace the Door Switch. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 28, 2010
My dishwasher FDB2510LCC1 get a cl code while washing and stays running on the wash stage until it is shut off
Hello Randy, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher is displaying an error code of "CL" this means close door. The dishwasher may not be sensing that the door switch is closed. The "CL" means that you could have a possible issue with the main control board or door latch. I would recommend checking to make sure the latch does not have any visible damage. This could also be a miscommunication within your dishwasher and a reset may help clear it out. In order to reset the dishwasher you would flip the household circuit breaker off for at least ten minutes. We hope this information is helpful to you. -Matt
Jan 28, 2016 | Frigidaire Dishwashers
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
Getting error code EO - F5. What's the fix???
Hello & Welcome to FixYa
Error code F5-E0 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Whirlpool RBS275PD Electric Single Oven
On the display is a flashing CL, according to the manual the latch is not closed. Tried several times to close the door and push the normal wash button. Nothing happens, only the CL light is on. Tried...
Hi
Daniel
Nov 26, 2010 | Frigidaire PLD2855RFC Dishwasher
It says CL washing and obviously isnt working
Hi
Daniel
Nov 26, 2010 | Frigidaire 24 in. PLD3465REC Stainless...
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open has a code 22
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code cl
See the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket. It could be that the unit is off balance making the door not even or enough play in the door so that the locking mechanisim thinking that the door was not closed try that.
Error Code: CL
Reason for the Code: Door switch open or door is open
Possible Component to replace: Door latch
Hope helps with this. Good luck.
Jan 20, 2010 | Frigidaire Dishwashers
My self-cleaning oven door will not latch. Displays error code dr
HI, This code will appear when there are serious issue that concern the integrity of the door latch mechanism. The control is unable to carry out the lock command, due to this mechanism failing, in this case. This damaged door latch assembly should be replaced asap. Once placed, the unit will preform correctly.
NOTE_ There is a possibility, that the door latch wires are loose. I would gain access to the door latch assembly, if possible, to inspect the wring that is linking the control to the actual door latch. Make sure the wiring harness is connected properly, and that the contacts are not damaged. If all is well, replace the door latch assembly
Nov 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
Frigidaire PLD4375RFC Dishwasher Logo
78 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
