Question about Fogel BC-65-DBST Beverage Cooler
Temperature adjustment how to adjust temperature of display cooler model 5006 SC
Have a problem with temperature with meat case from Howard/McCray model no. SC-CMS40E-8C Serial no. 09-26679-07 where can adjust the temperature or how to do that please
Up, down arrows next to temperature gauge. Press set, and hold for 10seconds till temp is flashing, then adjust by arrows accordingly, up or down.
Dec 11, 2014 | Refrigerators
How to adjust oven controll to the right temp.
You may find that your new oven cooks differently than the one it replaced. Use your new oven for a few weeks to
become more familiar with it. If you still think your new oven is too hot or too cold, you can adjust the thermostat yourself.
Do not use thermometers, such as those found in grocery stores, to check the temperature setting of your oven.
These thermometers may vary 20-40 degrees.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained
in memory after a power failure.
Adjust the oven thermostat-Do it yourself!
To Adjust the Thermostat
Touch the BAKEand BROIL HI/LOpads
at the same time for 2 seconds until
the display shows SF.
Touch the BAKEpad. A two digit
number shows in the display.
The oven temperature can be adjusted
up to (+) 35°F hotter or (-) 35°F
cooler. Touch the + pad to increase the
temperature in 1 degree increments.
Touch the - pad to decrease the
When you have made the adjustment,
touch the START/ON pad to go back to
the time of day display. Use your oven
as you would normally.
or self-cleaning temperatures. It will be retained
Dec 02, 2014 | Hotpoint RGB745 Gas Kitchen Range
My GE XL44 Self-Cleaning Gas oven heats up but is about 125-130 degrees cooler than what it is set for.
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The water is too cold in our newton water cooler. Is there an adjustment to make it warmer?
Yes there is an adjustment. Your water cooler should have a temperature control The enclosed adjustable thermostat is factory presetand should require no adjustment other than for altitude requirements. The temperature control should also be easily accessible.
Without specific model information difficult to identify where the temperature control may be located on your unit.
You might vist their website to identify your model. A search by model number may find more useful information on accessing and adjusting the temperature control.
Trust this is helpful.
Dec 17, 2010 | Computers & Internet
My oven is at least 15 degrees cooler than it should be. Since I have a digital stove, does that mean it cannot be repaired?
Try this
Turn oven temperature knob to OFF.
2. Press and hold both arrow pads for approximately 5 seconds.
3. A double digit will display ranging from -35 °F to 35 °F.
4. Immediately, press either:
• to increase oven temperature by 5 °F
• to decrease oven temperature by 5 °F
• When temperature is adjusted to a cooler setting, a minus sign (-) will
display with the offset temperature.
5. When desired temperature change is displayed, release control and
change will be automatically saved after a few seconds. Control will
return to time of day display.
• Offset temperature change will be retained through a power failure.
The complete manual can be downloaded at www.appliancehelponline.com just enter your model # and the manual will be on the left hand side.
Nov 05, 2010 | Amana ACF4215 Electric Kitchen Range
I need to adjust water temperature, and dont have a manual. i have a 81v40d C model , 40 gal electric.
Here is a tip that I wrote to help people understand how to adjust the temperature on their electric hot water heater.
Electric Hot Water Heater Temperature Adjustment
heatman101
Oct 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I own a spectra range Model # JBP30B0B4WH The problem is that the oven temp, is off about 15 degrees how can I adjust it? Roy
This is from page 13 of your manual:
Put the Oven Temperature knob in
the OFF position.
Press and hold the HOUR +/– pads for
5 seconds until the display changes.
Before display changes back, press
the HOUR +/– pads to increase or
decrease the temperature in 5
degree increments.
The oven temperature can be adjusted as
much as 35°F. or down as much as 35°F.
If the oven adjustment is set cooler
than the factory setting a minus sign (–)
and the adjusted temperature will appear
in the display.
Wait several seconds for the control
to automatically set and return to its
previous setting.
Feb 10, 2010 | GE Spectra JBP78 Electric Kitchen Range
Temperature setting is wrong. Stove is about 80 deggrees cooler than what the knob is set at. I am a yooper too.
If you think it is too cool, adjust the thermostat to make it hotter.
To Adjust the Thermostat:
1. Put the Oven Set knob in the OFF position.
2. Press and hold the HOUR INCREASE and the HOUR DECREASE pads at the same time for 5 seconds until the display changes.
3. Immediately, before display changes back, press the HOUR INCREASE or DECREASE pads to increase or decrease the temperature in 5 degree increments.The oven temperature can be increased up to 35°F.hotter or decreased 35°F. cooler.
If the oven adjustment is set cooler than the factory setting a minus sign “–” and the new temperature will appear in the display.
4. Wait several seconds for the control to automatically set and return to its previous setting.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained in memory after a power failure.
To Adjust the Temperature on Models with Only an Oven Set Knob
1. Put the knob in the OFF position.
2. Pull the knob off by pulling straight out.
3. Press and hold the HOTTER or COOLER button for 5 seconds to make the oven 20°F. hotter or 20°F. cooler.
When you are adjusting the thermostat, the following lights will flash indicating where the thermostat will be set when you release the
adjustment button:
OVEN ON indicates the thermostat will be set at the factory setting.
PREHEATED indicates the thermostat will be set 20°F. hotter.
CLEAN indicates the thermostat will be set 20°F. cooler.
4. After you have made the adjustment, replace the knob.
If you have any doubt please go through the manual which is given here
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rgb745.html
Hope this will help you
Thank you
Oct 02, 2009 | Hotpoint RGB745 Gas Kitchen Range
How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Feb 08, 2009 | Maytag MGS5770 Gas Kitchen Range
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Fogel BC-65-DBST Beverage Cooler Logo
Top Fogel Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Fogel Refrigerator Expert? Answer questions, earn points and help others
