Question about Kodak 5500 ALL-IN-ONE PRINTER
Looking For Chip resetter for kodak 10 cartridges
  • 4,041 Answers
Hi there
I not think they made one for a Kodak printers
Posted on Apr 28, 2010
2 Suggested Answers
don_farr
  • 1011 Answers
SOURCE: Kodak ESP 9 printer cartridges are not resettable
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Posted on Oct 22, 2009
Need KODAK #30 ink refill kit and chips or chip resetter
Kodak # 30 ink cartridge was made just for Kodak to help them get out of the red ink they are in. read the link below and see what they have done.
http://blog.atlanticinkjet.com/general-cartridges-posts/the-latest-printer-ink-from-kodak-inkjet-a-shift-from-the-cheap-ink-approach.html
Feb 12, 2012 | Office Equipment & Supplies
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
Mar 23, 2011 | Epson Stylus TX400 Series
How do reset my EPSON 6200 L cartridge chip?
Hello
Buy a smart chip resetter. It is available online for about $10.
Wipe clean the Epson cartridge using a paper towel. Pay special attention to the area where you attach the chip-resetter. Gently clean the copper nodes at the back end.
Clip the Epson chip resetter to the cartridge's back. Make sure the resetter's end with the button comes on the top.
Press the button on the top of the resetter and hold it for 5 to 10 seconds. This activity will restore the default OEM settings of the cartridge. The tiny LED light on some chip resetter models also indicate that the smart chip has been reset. The printer then recognizes the cartridge as full.
Remove the chip setter from the cartridge by pressing the release clip on the resetter's bottom.
Nov 11, 2010 | Epson laser Printer EPL-6200L Laser
HOW DO YOU RESET PRINTER CHIP ON ESP7
On the ESP5 printers the cartridge has a "chip" and unlike other printers that have tried the "chip" method to keep you buying their ink cartridges, however they did not do it right from a business point of view. The installed a chip on the cartridge that "remembers" how much it has been used, which means it can be "reset" however Kodak, a very smart and innovated company, they watched all the other printer companies and saw what they were doing wrong, so when they saw the chip reset ability the came out to be able to refill the ink cartridge, they fixed the problem by using a simple fix.
They have a serial number only "read only" chip on their ink cartridge and the printer its self remembers the serial number so you cannot reuse the cartridge, now as you might think there is a limit on how many it will remember so I use my printer a lot so I kept all my cartridges to see how many it remembers before it overwrites the older numbers, unfortunately I found the number to be twenty so you would need twenty one cartridges and I keep track of them by having a number on them so I don't mix them up.
So the way it would work is you can without modifying your printer, it you first would need to buy twenty one color and twenty one black ink cartridges, number them to keep them in order then when you refill a cartridge you take the oldest one next to place into your printer and it will read as new. I know this is a wild way to do it but it works.
I have tried to remove the internal battery in the printer so the memory resets and that works but I also have to reload the printer firmware every time I change the cartridge to reset the memory and that is a lengthy and difficult thing to do each time you need a new ink cartridge. I also found that the firmware reload will not rest the numbers unless you remove the memory battery in the printer, another brick wall.
I am still working on a way to get the printer to reset the serial numbers more easy and haven't found a way yet but I will eventually find a way to do it so keep your eyes open on the internet because it will be in all the internet tech news when I make an easy and effective way to reset the printers serial number memory.
But until then the twenty one cartridge method is the easiest but a bit annoying to have twenty cartridges laying around just so you can refill them. Actually from a company point of view, Kodak was brilliant with this method to keep people buying real kodak ink cartridges, because the read only serial number chip on the ink cartridge, cannot be rewritten, it is like the difference between the memory in a computer, the ROM and RAM, ROM "Read Only Memory" and RAM "Random Access Memory" you can write to the RAM but you cannot write to the ROM so most ink cartridges use a writable memory chip, so the information on the amount of ink stays on the chip on the ink cartridge, and the Kodak uses a Read only chip and stores the information on the amount of ink in the cartridge within the printer its self so a chip resetting device will not work.
I am thinking I can make a cartridge like device that will click into the Kodak printer that will cycle threw twenty serial numbers so a user can reuse the cartridge after refilling it.
So keep watching the internet tech news and when it is available your will see the news of it.
Sep 30, 2010 | Kodak ESP 5 Printer
How to reset cartridge informations?
Depending on your model, Use a chip resetter.
I have an epson printer, the chip resetter works very well.
Google "ink cartridge chip resetter"
Aug 01, 2010 | Computers & Internet
Kodak ESP 9 printer cartridges are not resettable for economic refill. Is it possible to get a chip resetting tool for the cartridges?
Don
Oct 22, 2009 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
How do i go about refilling epson T5591/2/3/4/5/6
Before you can have unlimited refilling you must need this devices:
Option 1: The chip resetter which you will need to manually reset the cartridge before refilling to enable the printer to recognize a new cartridge.
Heres the link where you can buy the resetter:
http://cgi.ebay.ph/CHIP-RESETTER-For-EPSON-T5591-T077120-T078120-T0791-INK_W0QQitemZ290276640766QQcmdZViewItemQQptZBI_Toner?hash=item4395d607fe
Option 2: You a new set of empty cartridges with autoreset chips in it. No manual resetting needed, what you need is to refill and monitor the ink level.
Explanation: When the printer detected that the cartridge is empty, the printer sends data to the cartridges and the cartridge understand what the printer says, then the cartridge automatic chip resetter will re trigger the logic circuit built in into it to reset into full ink level.
Here is the link of the autoreset chip what Im taking about:
http://www.made-in-china.com/image/2f0j00wCVtjAmMPlchM/Refill-Cartridge-with-Auto-Reset-Chip-Canon-520-501-.jpg
Oct 21, 2009 | Office Equipment & Supplies
Esp 7 cartridge resetter and color refill .
no,ink cartridges cannot be refilled .kodak printers dont recognize refilled cartridges and as such,ink price is very reasonable,clear liquid is white coloured ink. no cartridge resetter is available,cartridges are seated in the printhead of the printer
Jul 26, 2009 | Kodak ESP 5 Printer
Will not recognise all cartridges
some problems with compatible cartridges can be solved by taking all the ink out and powering the printer off then back on then put the ink back in, you might have to do this a few times also make sure no ink or dust has built up on the pins.
Sep 15, 2008 | Epson Stylus Photo R300 InkJet Printer
What is a chip resetter?
John, the chip resetter usually will not work on a faulty chip. You could make sure that the chip is aligned on the cartridge and connecting properly in the printer but it will generally be an electronic problem inside the chip itself. You will most probably need a new cartridge OR replace the faulty chip with the one off an old empty cartridge of the same colour, and then reset it using a "chip resetter" device.
Aug 10, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Kodak 5500 ALL-IN-ONE PRINTER Logo
2,397 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
