Question about Ionic Pro TURBO Air Purifier
When i turn it on it sounds like its hissing when it kicks on and off?
    Problem Solver:
  • 11 Answers
That hissing noise is the purifier plate working
Posted on Apr 29, 2010
Makes a hissing sound after I clean it
It may be a little late that I am answering your conundrum, but once you clean it, put the unit back together, tip it upside down until you hear a "click" and then turn it on. No hissing :)
Dec 24, 2010 | Sharper Image Ionic Breeze GP (SI730) Air...
How far in do the plates go and are they supposed to make a noise?
They should go as far so the back edge of the plates touch the back stop and the the metal clip on each side of the plate is touching the metal screen on the plate.
As far as noise, depending on the purification setting, they can make a hissing sound. If you see arcing or sparking, or hear any other noise other than a hissing sound, then it is time to replace the plates.
Hope this helps.
Jul 18, 2010 | Alpine Air XL-15 Air Purifier
Makes hissing sound, then immediately clicks to "clean"
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 28, 2009 | Ionic Pro TURBO Air Purifier
MOdel CA-500 is making a type of hissing sound. Almost like a zapping sound.
Dec 15, 2009 | Ionic Pro CA500 Air Purifier
Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
I have cleaned them well and have shaken alot, but still when I turn them on I get a hissing.
noise is normal, hissing and crackling all normal, you are magnatizing dirt with high voltage and causing it to stick to another magnetic section in the cleaner, these things operate on voltages in the range of 10,000-40,000vdc
Aug 11, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Gp sharper image hissing problem
1. Unplug the unit
2. Turn the unit upside down and listen for the beeds to move along the static wires from top to bottom. Turn it upside down again and again until you feel the static wires are cleaned of grime.
3. Plug it in again and see if the hissing is gone.
Jun 06, 2009 | Sharper Image Hybrid GP (SI724) Air...
Ionic Breeze - Black Quadra won't stop hissing
I have the same problem. The one thing that I DID notice is that it seems to occur more often in winter. Thus, I attributed it to dryer air conditions--too much static electricity being the culprit. With the unit off, I sprayed a fine mist of water into the housing and that cured it for a (albeit-short) time. Best solution would be to increase the humidity via a humidifier...
Jan 30, 2009 | Air Purifiers
Hissing sound intermittent on a ionic pro. hisses on levels low- med,-high.
my ionic hisses after we clean it and won't stop what can i do to stop the hissing?
laurie K
Jan 16, 2009 | Air Purifiers
One hissing one shut down
I have two Quadras not sure about the GPS. The only way to clean them properly is to complete the folowing steps. This will eliminate the hissing noises and intermittent shutdowns. Clean the blade unit as normal and leave it out of the unit. Unplug the unit, remove the four phillip screws on the top of the unit where the collector grid slides down. Next remove the four screws holding on to the base of the unit. After this you will see two additional screws also by the base that need to be removed. Look carefully between the grills of the unit and you will see about 12 to fifteen tiny screws that hold the grill together. After these are removed take off the UL label and seprate the grill. You may have to gently pull up on the top where the power switch is located. I have found if you use a lightly dampened scotch brite pad to carefully clean the two wires works best. Clean the wires and pins at the bottom and make sure all is well. Use a microfiber or lint free cloth to gently wipe everthing down and make sure the unit is dry. Put it back together and put the UL sticker back on.
Feb 12, 2008 | Air Purifiers
Ionic Pro TURBO Air Purifier Logo
383 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
