Question about Tomtom ONE GPS Receiver
Device will not connect to my computer
I have plugging my device into my computer and it will not connect. It says that the usb device is unrecognized. I have to install new drivers each time I try connect it to the computer, but this last time, it just will not connect.
  • 8,404 Answers
Is your device on the Microsoft Hardware Compatability list? http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Posted on Apr 28, 2010
Compatible charging cables for phillips go gear hdd1630/17
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Philips HDD1630 MP3 Player
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
I PLUGGED MY MP3 PLAYER INTO MY LAPTOP USB PORT AND IT USED TO WORK NOW IT SAID THE USB DEVICE HAS EXCEEDED ITS POWER LIMITS OF ITS HUB PORT AND WONT WORK NOW
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Sep 05, 2011 | Computers & Internet
QUESTION; CAN MY XL GPS BE CHARGED BY PLUGGING IN TO THE COMPUTER?
Yes, you can plug your GPS device into your USB port to charge it. Your computer (if running) will assume you are connecting the GPS device to your computer, and It will start up the program for your GPS device... e.g. to update the map, backup the data, etc. You can proceed to do all that, or ignore those programs. While it is plugged into the USB port on your computer, it will charge your GPS battery. You may wish to "disconnect" the GPS device (properly), but still leave it connected ... to continue charging it.
Another way to charge the GPS device is to get a wall plug USB adapter. This way, you can charge the GPS battery without having to go through the complexity of what the computer does when you plug the USB cable into it.
Jan 02, 2011 | Tomtom GO GPS Receiver
Im tryin to connect my USB in the computer to put my pictures on the computer but it wont let me ???/
Hello
A few questions that may confirm problem.
Does your computer seem to know that something is plugged in?
Or does it say that it does not recognize the device?
Well, if the computer actually knows that a device has been plugged in, but you just cannot see the device in my computer, here is how you fix that. Just follow these steps:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your device presented in the schematic below.
Right click on the device and assign a new drive letter.
If your computer states that it does not recognize the device, try plugging it in one of the back USB ports of the computer. Please rate this.
Best regards
Sep 30, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
I have no idea how it happened, but i plugged it into my computer to charge. and then i just saw my mp3 player and the screen froze and it says usb connecting and when i plugged it out it still said usb...
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Nov 28, 2008 | Samsung YP-U3 MP3 Player
Usb ports
  • The driver for the device is faulty. When you plug in a USB device, the computer should load and then configure the device without ever requesting a device driver. If the computer prompts you for a device driver, check the information that came with the device or go to the manufacturer's website to see if a driver is available.
  • The USB port might be defective. If the USB device is connected to a defective port, the device will not work. Try plugging the device into a different port. If all the USB ports are being used, unplug a device that you know works, and then plug the problem device into the port that device was using.
    If the device is plugged into a secondary USB hub with other USB devices, unplug the device from the hub, and then plug the device directly into a port on your computer.
  • Other USB devices might be drawing too much power from the hub. The device you are trying to use might require all the available power or bandwidth that your computer can provide. If other USB devices are connected to the computer and are drawing power from it, the first device might not work. If any other devices are drawing power from the hub, try disconnecting them, and then see if your device works. If this solves the problem, you might want to obtain a USB hub with its own power supply so that you have adequate power for all devices.
  • Oct 23, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    Usb write protect
    If you've updated your software and checked the drivers but the issue still persists, try the following things:
    • Unplug the USB device and then plug it back in. Make sure that the connection is snug and installed in the proper direction. Note that USB plugs fit one way only—if you try to plug them in upside-down, it will not insert.
    If this does not solve your issue-
    • Unplug all USB devices from the computer. Then start plugging in USB devices one at a time, testing each one to make sure they all work before adding the next. Sometimes two devices will conflict and will work together.
    • Is this a new device that never worked, or is it a device that you've had for a while that suddenly stopped working? If it used to work, think about what changed just before the device stopped working. Did you recently add another new device? Install a new program? Try reverting the computer to the way it was before the device stopped working. If it works again, there is an incompatibility with the device and whatever you added.
    • Unplug all but suspected USB devices. Open System Devices menu-
      • Windows: Right click “My Computer” > Properties > Hardware > Device Manager > USB Serial Bus Controllers
      Under the USB information, you should see the USB devices connected to your system. (Disregard any Host controllers) The name may not be identical to your device (it may say “USB Mass storage device”), but it should have the right number of devices listed.
    • If you have the device plugged into a USB hub or into your keyboard, plug it directly into one of the USB ports on the computer. If it works there, the issue is with the device to which it had been previously connected. The device may need more power than the port provides
    • Try a different computer!
    Sep 23, 2008 | Centon Electronics USB 2.0 PCMCIA...
    Tomtom ONE GPS Receiver Logo
    168 people viewed this question
    Top Tomtom GPS Experts
    k24674
    Martin Murray
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
