Question about Kenmore Elite 45986 Front Load Washer
I have a kenmore he4t washer and the front door
I have a kenmore he4t washer and the front door won't lock.
  • 1,998 Answers
First thing to check is if your door hinge has a sag to it. The next step if there is a sag is try adusting the screws that hold the hinge on the frame of the door sometimes these do come loose. and do require tightening. Folowing confirmation that there is no sag in the hinge your next step would to order a new door latch. If you are not mechanically capable of removing the front section of the machine you should call a technician
Posted on Apr 28, 2010
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
DOOR WONT LOCK KENMORE ELITE HE4T
Before removing try some WD40 spray on the door mechanism, not on door.
Aug 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4t Washer stuck in "controls locked" mode
you need a new cpu you can unlock door by removing bottom panel reaching up to the door lock and pulling a little ring on the bottom will manualy unlock the door
Nov 08, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore 3.8 cu. ft. HE4t King Size Capacity
remove feet set on stand and put the 4 screws in 2 in the front 2 in the back the remove the drawer and level the 4 legs on the stand then lock the lock nut if you git a little vibration raise the front washer up 1/8 in usely will take care of it
May 03, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
387 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
