Question about Garden
My Scotts Turfvac2 lawnmower is not getting fuel. I must hold in the primer bulb in order for it to run. I have change the fuel line, changed the oil and gas and replaced the spark plug. It does not appear to have fuel filter. Any suggestions?
  • 143 Answers
SOURCE: My craftsman 6.75hp mrs lawnmower dies out after a
You will have check the carburettor. If you cleaned the air filter, the carb.is right under it. Or if you follow the fuel pipe from the fuel tank it will run straight to the carb. Remove the round bowl at the base, it is held on with a small screw at the bottom. Clean this out and blow out the carb. with air. You may have to remove the whole carb. to clean it right. Good luck, Stephen.
Posted on Sep 29, 2009
SOURCE: I have a Craftsman 6.75hp MRS mower/mulcher.
try taking one bolt off bowl under carborator --see if small pin come loose that holds float on--thats what happened to mine
Posted on Oct 06, 2009
  • 2239 Answers
SOURCE: Walbro WT891 carb on a
Who connected these hoses? the normal routing for a machine with a primer is like this, the fuel hose from the tank with the filter on the end goes to the carb fuel inlet nozzel ( not to the primer ) nearest to the pump cover ( cover on carb held with one screw ) the pipe from the metering side of the carb connects to the shorter nozzel on the primer bulb ( suction side ), the longer nozzel on the primer ( pressure side ) connects to the pipe going back to the tank, just remember the primer pulls fuel from the carb,into the bulb, and pushes it back into the tank, it is not actually a primer it is a purge. because it is connected this way it is impossible to flood the engine no matter how many times the bulb is pressed.
Let me know if it starts and runs.
Posted on Jan 31, 2011
  • 130 Answers
SOURCE: i change fuel lines. when i push the primer bulb,
You need to make sure the fuel lines are hooked up properly. This is a common error when replacing fuel lines. Not knowing what model equipment you have I will take a stab at the routing. One line goes into the tank with a filter and the other end hooks to the carb. fitting closest to the fuel pump side of the carburetor. One line goes from the "out" of the primer and is a return line straight to the tank. One line goes from the "in" of the primer and hooks to the other fitting on the carburetor. If any of these lines are interchanged, you will not get the proper prime. Hope this helps.
Posted on Feb 21, 2011
Testimonial: "this is exactly what caused my problem."
2strokeJim
  • 577 Answers
SOURCE: I changed the primer bulb and now it's not getting
sounds like you hooked the lines up backwards, when you press the primer it is supposed to squirt gas into the tank on the return line cause what it does is draw fuel through the carb and back to the tank....filter line from tank goes to fuel pump side of carb and return line on carb goes to primer bulb then opposite line on bulb to tank...... so when you press bulb it draws fuel through filter in tank through carb and back to tank ! good luck! 2StrokeJim
Posted on Jun 17, 2011
Carburetor change
Primer bulbs pull fuel from the carb, into the bulb and dumps it back to the tank, if you have re connected the hoses to the primer the wrong way around it will try to force fuel into the carb and make it flood.
Jun 01, 2013 | Poulan Garden
Jun 17, 2011 | Homelite Garden
Missing T piece from primer bulb to carburator
Sears has replacement parts and so do the OSH stores. If there's no store close, check with a local lawnmower shop and I'm sure they've got lots of replacement parts.
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Primer Bulb cracked Need new one?
remove carburetter air filter cover,two 'torx' screws on top.primer bulb is retained in case by 2 plastic 'ears' push ear[s] in& bulb slides out of case.make note/label 2 fuel lines attached; one 'stem' on primer is longer than the other.replacements can be found @ lawnmower/small engine repair shops.
Oct 10, 2009 | Garden
Fails to stay running / primer bulb does not fill
Double check that the fuel lines are routed properly. Another place to look for a potential problem is where the fuel line comes out of the tank. Make sure the hose is not pinched. The typical fuel line routing is the first line (the one with the fuel filter in the end of it) comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb and the third line goes from top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 04, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I changed the fuel line going from the fuel tank to the primer bulb and now my weedeater will not stay running and my primer bulb is not holiding fuel.
Make sure the fuel line is a good fit to the carb. ... If is sucking any air at all it won't run right.. Also check that the fuel line in the tank is still hooked up...
May 20, 2009 | Ryobi Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Petrol lawnmower cutting out.
try changing the spark plug. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal.
Aug 29, 2008 | Garden
Garden Logo
295 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
