Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
The refrigerator on my SubZero 650 is too warm. I set 38 F and the indicator goes directly to 48/50 degrees within a second of me releasing the temp select button. Freezer works fine. I have cleaned the Condenser and no change. Service light not illuminated.
  • Sprockhead70 Apr 28, 2010
    Well, yeah. But that is the problem - the temperature is too high. Up until about 2 days ago, it always showed 39 degrees when i opened the door (the temp I had it set to). If I left it open for a few minutes, it *might* rise to 40 or 41 degrees. But now it won't go below 46.
    So far I have tried vaccuming the condensor and restarting the unit - but the vaccum condensor light keeps turning back on. Pretty frustrating...HELP!
    -Pat
    So far I have tried vaccuming the condensor and restarting the unit - but the vaccum condensor light keeps turning back on. And it still won't go back under 46 or 47 degrees (despite setting the temp even LOWER to 34 degrees)
    -Pat
I had a similar problem.The problem was attributed to a faulty FAN switch,That fixed the problem. The light switch and the Fan switch are different.FAN switch is normally closed while the Light switch is normally open.
Posted on Sep 26, 2012
  • 668 Answers
Check for frost building on the back wall in the freezer. If this is happening, the unit is not defrosting and this frost will block the air flow to the refrigerator section. The air flow from the freezer is what cools the refrigerator and without it, the refrigerator section will get warm.
A technician will be required to make these checks.
Hope this helps.
Posted on Apr 28, 2010
  • 355 Answers
I believe it's showing the actual temperature that it's currently inside the refrigerator, not the temperature it's set at. At least that's how my sub zero works. You may need to clean the coils to get it to cool better.
Have had this refrig. for several years and have had no problems until our 2 year old grandaughter played at the temperature controls about a week ago...The freezer has been set at -2 and the regrigerator...
Hi there
Samsung's child lock is easy to alter
Press the vacation and fridge temp buttons simultaneously and hold for 4 seconds, this will release the child lock, to reinstate the lock just repeat this. 4 seconds is quite a long time.
Hope this helps
Gordon
Apr 20, 2011 | Samsung RB215LASH
I have 685, what is the best temperature for the fridg and freezer
Dear strusler,
We recommend that the refrigerator be set at 38 degrees F and that the freezer be set to 00 degrees F.
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Feb 21, 2011 | Sub-Zero 650 / O Bottom Freezer...
VACUUM CONDENSER MESSAGE KEEPS COMING ON subzero 650. I vaccumed it several times! The temp gauge is showing 48, yet the tem is set on 38
you need to turn off main power to frig...wait 5 mins..plug back in...if does it again replace sensor by condnser coil you cleaned..please ,on the side you cleaned flash a bright light thur it if you see no light, its plugged...then take compressed air an blow thur it...will be a little dust...vaccum up...hope it will help...michael,doctor airr appl.repair..843-384-8474...call if need more assistance..good luck...
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
The tempature is set for 38 degrees, but the refrigerator is only at 47 degrees. Any ideas?
Chartigan - had this problem with my 1998 642 about 5 years ago, and had to have the condenser coils replaced twice- because the refrigerant was leaking. warning signs are: temp is more than 37 degrees [ get a fridge thermometer to monitor], food seemed to spoil quickly, and frequent notices from the display bar to clean condenser . after cleaning it 3 times in a month, when i called the service center they said that warning actually means"call service center" - arrrggghh the manual sure doesnt say that! anyhow - just something to consider, and hope your problem is not this serious.
Aug 01, 2009 | Sub-Zero 642
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Vacuum condenser message flashing
Your evaporator needs replacing. covered under 12 yr. warranty parts only.
Jul 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,481 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
