Question about Fisher and Paykel GWL11 Top Load Washer
Ok so its broke..what is easiest way to get out water....
  • keke lewis May 25, 2010
    how do i put my pic on dis fixya
  • Fisher and P... Master
  • 43,501 Answers
Use a hose like a garden hose about 5-6 feet long...you can use your mouth the pull water up the hose and then drop it over the edge into buckets and siphon the water out of the tub....
Then check out this tip...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 28, 2010
Testimonial: "thanx!!!!!!!!"
How do I turn down thermostat on this water heater?
The temperture of a water heater should be approx 120 degrees. If you use a dishwasher that is the desirable tempurture to kill bacteria.
If your heater has two thermostates then make sure they are set for a 5 degree difference between them
Good Luck,
Marty
May 06, 2014 | Rinnai Water Heaters
Karcher k2 36
IF the area that broke is the bottom of the pump, you will have to replace the bottom part of the pump or the whole pump. IF you are not mechanically inclined, the easiest is to replace the whole machine, followed by the pump and then the part.
Feb 22, 2014 | Garden
Washer is stalled .takes water and drains water ok .. bur do not agetate and does not spin
need to know what kind of washer sounds like a whirlpool or kenmore if that is the case there is a coupler between the motor aned the transmission you can tip the machine back to see if part is broke, it is two plastic pieces that connect to one rubber piece either plastic will be broke or rubber will be torn
May 12, 2011 | Washing Machines
Timing belt broke did it bend any valves
This engine has been identified as an interference engine in which the possibility of valve to piston damage in the event of timing belt failure is most likely to occur, when repairing I would also replace water pump, due to pump is timing belt driven. On an 2002 VW Jetta TDI 1.9L engine, VW recommends timing belt replacement every 80,000 miles.
Aug 24, 2010 | 2002 Volkswagen Jetta TDI
My ac belt broke. Is it safe to drive the vehicle? Is it fairly easy to replace?
As long as it only is the ac then its fine, just replace it when you got some spare cash, or want heat back
Aug 12, 2010 | 1995 Isuzu Rodeo
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Some kind of water flow or thermostat box is broke
It is the water inlet housing. It has a pipe screwed to it that goes under the lower intake. You can unbolt the pipe and change the housing but the easiest way to do it is to remove the upper intake. I was in a carquest store the other day and they had these housings in stock.
Apr 08, 2010 | 2001 Chrysler Concorde
My window regulator and clips broke on the passenger side of my 1999 grand am. where can i get replacement parts?
these clips and regulators are often reproduced as aftermarket parts. sometime napa or autozone checker etc. will have these parts.
I usually go to the dealership for the clips, because that is the easiest way to get the correct ones and they are not too expensive.
Alot of the time on these windows the clips will break and the regulater is still ok.
Confirm the regulator needs to be replaced before buying one. if the roller is broke off, I have been able to buy just the roller, and replace just the roler. but it has been a long time and I dont remember where I got the roller, or if it was a roller specificly for the car I was working on.
Jan 27, 2010 | 1999 Pontiac Grand Am GT
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
