Question about Cyberhome DVR 1600 DVD Recorder
I cant get my dvd player to accept the disk...it keeps saying no disk
  • 417 Answers
A few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Posted on Apr 28, 2010
When I insert a blank DVD+R to copy a VHS, It reads the disk, says "Unknown Disk" and ejects it. How do I record if I can't keep a disk in the machine?
What speed of disk did you use? On my older machine if I use faster than 4X it will not accept the disk. Check out your disk an see if the record speed is to fast for the machine.
Jan 29, 2015 | GoVideo VR3930 DVD Player/VCR
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
My dvd won't play. every dvd i put in, it says bad disc. the vcr works fine. is it time for a new system. i tried a head cleaner and it says bad disc
Not necessarily time for a new one. I would give the DVD player a good cleaning before you consider a new unit. A good cleaning disk with some little bristles on it. Run it through three full times. DVD players are far more sensitive than VCRs and have to be cleaned even two weeks or so. When they get real dirty it can take some fooling with to get the DVD player to even accept the cleaning disk. But if it just won't accept the cleaning disk and you can't watch a DVD in it then it's time for a new one. I had a DVD player one time that took an hour of fooling around with before it got cleaned good enough to play DVDs. Worked for a couple years afterward.
Regards, Tony
Apr 19, 2011 | GoVideo Go Video DVD/VCR Combo
I cant eject the DVD. It keeps saying "Please
Try pressing repeatedly the eject button while you turn on the unit. If this doesn't work then it is a mechanically problem in your player.You need to be manually open to take out the dvd.The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.
You need to place the rubber thread to proper place.
Furthermore, if the belt is slipping, the mechanism never gets the "drawer closed" signal, and the disk will not spin.
After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. So it indicates the defective laser motor. The only way to fix this problem is to bring the unit to a service center for repair.
Hope this helps.
Please feel free to ask us if you have any further queries.
Shane
Feb 13, 2011 | Kiss Technology DP-600 DVD Player
My ilo dvd R/P will not record and keeps saying invalid disk,
TILO DVDR04 PLAYER RECORDER THE DVD RECRDER IS IT SPECIFIC TO THE DVD RO4 CAN IT BE REPLACED WITH ANY PLAYER BURNER IT SEEMS TO PLAY NORMALLY.
Mar 08, 2010 | iLO DVDR04
Won't accept disks (any kind)
try universal dics for you dvd.maybe it is not compatible with your player...
Apr 15, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
I cant get DVD RW disk to work in ny dvd recorder DVDR5500
This player only accepts DVD+RW rewritable discs. Some players are also fussy with which brands you use. If you are using DVD+RW and it isin't working try another brand of disc.Hope this helps.
Aug 30, 2008 | Philips Televison & Video
Will not record says disk error i have aq new disk in
install disk to record from dvd to hdd using dvd-rw dvd- dvd+ disk not een accepted cannot record from hdd.
May 24, 2008 | Televison & Video
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome DVR 1600 DVD Recorder Logo
274 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
