Question about Freezers
Frost in the freezer
Our 7 year old freezer got icey over the easter weekend while we were out of town. Door was shut. Maybe some food is blocking something? Any ideas?
    Novelist:
  • 184 Answers
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Posted on Apr 05, 2008
SOURCE:
FRIGIDAIRE CHEST FREEZER WILL NOT FREEZE FOOD OR KEEP FROZEN
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 13, 2013 | Frigidaire FFFC07M2KW 7.2 Cubic Foot Chest...
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Temperature Alarm
although you could just close the door and it should right itself,could it be the right time for a total defrost and clean.all the drains/vents.....auto defrost only does the inside of the unit,
Jun 24, 2010 | Frigidaire 13.7 cu. ft. Upright Freezer...
I have Hotpoint freezer 9764. Quite old now but
the coldest part of a freezer gets frosted up the fastest( i cannot believe you are running a freezer with no door !!!!) like running a/c with doors open
just replace the seals asap.
Mar 21, 2010 | Freezers
ONLY HAD THE FREEZER ABOUT 2 YEARS AND GOT HOME TODAY AND IT WAS COMPLETELY THAWED...LIGHT WAS ON BUT IT WAS WARM? UNPLUGGED IT AND REPLUGGED IN AND IT STARTED RUNNING>>>ANY IDEAS WHY THIS...
this happen to me a couple of times:
once the kids didnt completely close the door and everything defrosted so i got the key and keep it lock so it wont happen again
the other time (frigidaire model) i put too much food on the top shlef and blocked the air vents and it defrosted as well.
but both times after i corrected the problem its been working fine
but if your freezer still doen't work let me know...
also if your prob. isn't like mine then it could of been something else like defrost mode was running too long... compressor didnt come on
tstat stuck closed... timer mode stuck in cycle...
let me know so i can go over again if you need more help
Mar 12, 2010 | Freezers
When I shut my freezer door, the freezer makes a hissing sound for roughtly 15 seconds, during which, the freezer door wont open. At the moment there is no food in it, could that be the problem?
the auto defrost fan is drawing the air out to cut down on frost buildup....when you do put food in freezer use vacuum sealer to stop freezer burn and keep portions seperate,easier to rotate food for consumption.also frozen meat can be kept for upto a year at minus 18/20c
Feb 21, 2010 | Freezers
Freezer not Freezing
ok promblem 1 raise th front levelingm legs so that when the door is released from opening 1/3 of the way it shuts its self promblem 2 if the ice gets so thick it blocks the air intake of the freezer it cant cool your defrost drain is blocked its under the back panel in the freezer and needs to be cleared
May 26, 2008 | Frigidaire 11.6 cu. ft. / 328 liter...
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Freezers Logo
447 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
