Question about Kitchen Ranges
I have a hardwired door bell at my front door. It rings up on the second level. I spend alot of time in my garage and would like to install another chime in the garage that is wired to the same switch. I bought another chime and transformer but when I hook it up to the same switch it makes bad noises. must be back feeding with the other transformer upstairs through the switch. How should I wire this correctly for 2 chimes using one doorbell?
    Guru:
  • 415 Answers
Hello dj303dj3. I am going to help you. I am working on a wiring diagram now and will get back to you tonight. Many thanks! :-)
Posted on Apr 28, 2010
  • 1 more comment
  • laura Newman Apr 28, 2010
    Hi dj............ I need to know a few things about your doorbell chimes and your transformers. I need to know the Amperage of the chimes and the VA of the transformers.
    Thanks,
    Laura
    Also need the voltage of the transformer and chimes.
    I'll look forward to hearing back from you with any questions, comments, concerns. :-)
What is key dance so dummy bell will signal if i leave lights on
Another american invention bells and bleepers that drive me insane when repairing cars and the door is open dong dong dong ,fixing the lights ring ring ring ,key in ignition bong bong bong .look in the fuse /relay box inside the car and thier you should find the annoying little speaker thingy pluged into here and it normally looks like a relay with speaker holes on the side .
May 30, 2014 | 1999 Ford Windstar
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
May 12, 2014 | Heath Zenith SL-6144 Specialty Series,...
LiftMaster garage door opener won't open. When push button (from either remote or "door-bell" style button on wall), unit makes a slight humming sound for a couple of seconds, then nothing...?
Check the door springs and also the drive gear. The gear is a white nylon gear just in front of the motor unit. It will be pretty obvious if it is going bad. The door spring may be broken.
Oct 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener has stopped working. No
There isn't a reset but make sure the trolley isn't jammed against the bolt just in front of the motor unit.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My controls will not open or close my garage door. The wired control works. I read that the logic board is bad. How much is the logic board and how hard is it to install. Is it better to just get another...
A new board is @ $86.00. Because I do not know your skill level I really cannot say whether it is easy or hard to install. I have replaced boards and I find it easy, but my brother would find it impossible. So it is subjective and you know your own skill level better than anyone else. I personally feel that it is not too complicated for a typical homeowner to do. In this economic time, some people have no choice and cannot spend the extra money for a new opener, but again I do not know your financial situation either. So the choice is yours, but if you can use a screwdriver and stand comfortably on a ladder, I would replace the board. I hope this helps and good luck!
Please remember to vote c5e7dfb.jpg and leave a testimonial. Thanks.
Nov 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hardwired code opener no longer works
Here are the directions to program your hardwired keypad.
First unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Oct 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
If there is a missing door opener, how do i delete all the openers and start over.?
You can hold the smart/learn button in for 6 seconds and this will erase the memory from the logic board. None of your remotes or keypad will work at this time. The wall control which is hardwired will still work. Now you must program your keypad and remotes.
Oct 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
We moved into a house with a LiftMaster garage door opener that we are guessing is almost 10 years old. No problems when using the one handheld remote we were given or the wall control; however, when...
Just to satisfy me would you try your original handheld remote once to make sure it is working properly. The wall control is hardwired so it is not a question.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor run chain not moving when i hit hardwired stop and start button
You need to check the drive gear. Remove the cover and it is a white nylon gear just in front of the motor. Most likely stripped. The part number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Ranges Logo
79 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
