Question about Compaq Presario R3000Z Notebook
Hi my computor just recently went into hibernation mode and it won't turn to my original screen.I'll tell you what happend.It went to a black screen last night and i don't know if it crashed or not because it wouldn't turn on and so i turn on this morning and it said hibernating and its bin like this all day.I turn off my power key and the blue button goes to orange and then doesn't blink except for the power button that blinks all the time.So when i turn it back on its still hibernating and i was wondering if i should call the my compaq computor for technical support or do would you know the answer to fix this problem ?
  • 29 Answers
When your computer boots up press F8 after the boot screen, its easy to miss the short period you can press this. This should prompt a screen which allows you to choose how to boot windows. Booting windows normally (without restoring hibernation state) or in your last good configuration that worked (it saves restore points pretty much every day your on it and will revert to that restore point) will be your best bets. Hope this helps, let me know if it gets tricky.
Posted on Apr 28, 2010
Stuck in hibernation mode only get black screen
Probably if you can hear the hdd runnng and lights are switching on and off then, the display cable is undocked. Try openning the machine side if not, then the screen side cable.
Mar 20, 2013 | Computers & Internet
My laptop screen went black. Laptop won't turn
It powers on but there's no visible picture. Have you tried plugging in a VGA cable to an external monitor for picture? If you see a picture that means the lamp inside the screen went out on the LCD, which is cheaper than replacing the entire screen about 200 dollars cheaper.
Apr 08, 2010 | HP Pavilion dv7-1132nr Notebook PC
When i turn my comptor offarejust exit outof internet explorer and leave when i come back the computor seems to be in the sleep mode but theonly way i can wake it is by un pluging the power cord and re...
it's probably in hibernate mode. go to your display properties ->screen saver, click the power tab and check the hibernate tab, try disabling hibernate.
Sometimes, if a machine won't properly wake from sleep, there may be a bug in the BIOS, you can try updating to the latest BIOS for your machine. Check the manufacturer's website to see if an update is available.
Oct 05, 2009 | E-Machines eMachines Desktop PC
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
I left my laptop on last night (got called away to work) and now it will not turn on. The blue light comes on yet i have a black screen
it went in hibernation mode
try to push power button at least 6 second
The laptop should shut down
Now restart the computer
tell me if it works
Jul 08, 2009 | Gateway Computers & Internet
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Compaq pesario C300 not starting
Have you tested your harddrive to make sure it's working properly,or you are maybe missing ntldr
Dec 10, 2008 | Compaq Pesario S4120WM (DK216AR#ABA) PC...
HP Pavilion ZD8000 unable to go into standy or hibernate mode
Have you looked through all of your power options under
Control Panel -> Display -> Screen Saver (TAB) -> Power (look at these settings).
Apr 18, 2008 | HP Pavilion zd8000 Notebook
Theres no display on screen
by shutting the screen you have activated power saving followed by hibernation.when you lift screen and press power a screen appears telling you what programs are currently running and your icon to enter.by removing battery you have (computer term) illegally shut down,possibly with programs running,which incidently is a good way to loose sys32. which would require a repair or install.
Not ur case as of yet.restart ur pc and press f 8 about 4 seconds later .black screen with options appear ,navigate to start windows with last good configuration.windows will restart with last good settings .
if you choose to go asleep whilst a program is running you can configure windows not to go into power save mode or hibernation,turn off hd,turn off pc etc .
if you right click mouse in any space on desktop,select properties,screensaver,power.....you can change settings there to suit.
Mar 06, 2008 | IBM ThinkPad T43 Notebook
Compaq Presario R3000Z Notebook Logo
216 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
