Question about LG Washing Machines
Lg wd-8013f has the lights flashing but wont work at all. None of the buttons do anything when I push them it wont even turn off.
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
hi all you poor owners of this heap of junk, i have one too with the same problems, the shaking and moving around the bathroom was stopped by welding a 1/2 inch long piece of 1 &1/2 inch dia pipe to a 2 inch square flat plate of steel then putting double sided sticky tape beetween the plate and the floor
where you want the front rubber legs to sit, this stops it from running around the floor but it still needs to adjusted to have the
same on the front two legs to stop the shaking.by leaning the machine back a bit also helps to stop it leaking so bad while filling, it is only from the condersation from the hot water going in and the poor design of the soap drawer not allowing the water to run back into the washer which can be fixed by cutting the lip off
the bottom wher the drawer slides in then running a bead of silcone in the crack between the front cover and the inside piece
then another one on the front edge to run the water back into the washer. hpoe this helps. bryan.
Posted on Feb 26, 2008
SOURCE: lg intello wash wd 8013f
The front panel is flasing when i press play
Posted on Sep 16, 2008
  • 300 Answers
SOURCE: It doesn't let me choose a cycle - doesn't work
the control pannel faulty needs replace ment. press the cancel/pause button and clean button together to reset the board.check it if gets reset then it will work orther wise replace control board.
Posted on Mar 07, 2009
  • 30 Answers
SOURCE: lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Posted on Mar 18, 2010
  • 713 Answers
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
Posted on May 13, 2010
I do not know how to undo the child lock on my LG intellowasher Model no.WD-8013F
The Child Lock can be activated and deactivated by pressing and holding both the Temp button and the right Option button simultaneously for 3 seconds as shown below.
Let us know if this procedure fails to deactivate the Child Lock feature for further troubleshooting and repair advice.
Aug 23, 2010 | LG Washing Machines
Lg intellowasher wd-8013f is very noisy
May 09, 2010 | Washing Machines
You suspect right.
Good Luck
Mar 17, 2010 | Washing Machines
LG WD 8013F drains then won't spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 21, 2009 | LG Washing Machines
Mar 07, 2009 | LG Washing Machines
WD- 8013F - LG
im soor y but i dont know much about the LG applaince line, but what i do know is if they are saying that the door switch is at fault, perhaps its a wire harness leading to the switch or the control board is not reading the door switch is pushed. sorry couldnt help further, if i do hapen to see anything on here about that i will surely foward it to you!
Nov 18, 2008 | Washing Machines
Touchscreen turned itself off and keeps flashing. HELP
To fix this problem you will have to go to your local phone dealer. They would usually fix it up for free!!!
Sep 13, 2008 | LG KU990 Viewty
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
Washing Machines Logo
214 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
