Question about HP OfficeJet J4580 All-In-One Laser Printer
How do you change the number of rings, so that the fax will pick!
I have it set to auto answer and 2 rings and it won't answer. It worked this morning and then just stopped. the test fax all passed as well. any suggestions?
Posted on Jun 30, 2010
    President:
  • HP Master
  • 2,022 Answers
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Apr 28, 2010
4 Suggested Answers
  • 105 Answers
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Posted on Oct 05, 2008
frcs68
  • 1605 Answers
SOURCE: Increase the number of rings
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Posted on Jan 13, 2009
seeker5211
  • 1089 Answers
SOURCE: how do i change the number of rings before fax
Menu/Fax Setup/Enter/Fax Receive Set up/Enter/Rings to Answer
Posted on Feb 06, 2010
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
How do I lessen the number of rings when receiving a fax?
Check On your Manual for Ring setting or Press Menu Setup on your Fax Check for phone setting and set our ring setting
Sep 29, 2010 | Samsung SCX 4521F All-In-One Laser Printer
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Office Equipment & Supplies
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Changing the amount of rings
Pick the phone up earlier it will stop ringing......:-)
To set the number of rings-to-answer
To set or change the number of rings-to-answer, use the following steps:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Fax setup, and then press tick
3. Use the < or the > button to select Fax Recv. setup, and then press tick
4. Use the < or the > button to select Rings to answer, and then press tick
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press tick
But I still think picking up the phone earlier would be easier
Your Manual, please rate as fixya or post back
Dec 28, 2007 | Office Equipment & Supplies
Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Jan 21, 2007 | Panasonic Workio DP-2330 Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
167 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
