RCA L42WD22, message: unusable signal - Televison & Video
  • tz48mz Apr 28, 2010
    fuse replacement guide or pictures?
  • 4,889 Answers
Whats the input source you are using? Cable box? DVD player? Did you try another source to see if problem persists? Please provide this info so that I cna help you with your problem.
Sai.
Posted on Apr 28, 2010
    Genius:
  • 1,043 Answers
There is a fuse on the digital board of the TV that need to be replaced. The part number is F1455CT-ND, and can be found at the following website:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=F1455CT-ND
The cost of the fuse is $0.81. You may want to order more than one as that particular part has a bad habit of blowing out. If you're not sure where the digital board is located you can do a Google search using your model number and the words "service manual" (if you use the quotes around service manual you will only see the pages with those exact words together), you'll find a number of sites that will allow you to download the manual for around $5.00.
Unusable signal shows up on screen.Cannot get a cable signal.
Hi friend I would recommend that you plug your TV into a cable signal that is currently working on a different site and see what the TV response is if the TV has the same response the RF modulator on the port panel could be faulty if TV works fine then I suspect your cable signal strength and quality at your home is either non existent or extremely poor and will have to repaired. Good luck hope its not your TV.
Dec 17, 2010 | RCA L42WD22 42 in. LCD Television
L42wd22 "no signal" and no audio
Exactly one year ago our TV did that. Now our TV is in the service center cause it has no screen.....just a plain black screen. However last year when we had it in we had that "no signal" message. It was not the same problem. It had something to do with wiring on the master board...thank gosh for warr. Otherwise I was told it would have been a $300-$500 repair.
Best of luck!!
Apr 21, 2010 | RCA L42WD22 42 in. LCD Television
L42WD22 42'' TV sas unusable signal All connections good
We found a solution on another site that did not charge, but thnx anyway.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
THE tv L42WD22YX5 turn on ok , apear unusable signal no sound no video what problem is_
your mainboard is failing and will need to replace this company as well as many others do not sell part seperatly only at board level you can try shopjimmy.com or call a local shop to help you
Dec 02, 2009 | RCA L42WD22 42 in. LCD Television
Model L42WD22 unusable signal
did you ever find a solution for this... I am experiencing an issue with 'unusable signal' and have my cable through Rogers
Oct 16, 2009 | RCA Televison & Video
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
RCA L37WD22 not receiving analog
The problem is on the signal board. Same problem and fix for L42wd22, and L46wd22 models.
I can fix this board for a FRACTION of what a repair tech will charge you. Email me at aplusrepairs@triad.rr.com
May 11, 2008 | RCA L37WD12 37 in. LCD HDTV
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
