Question about Kodak Easyshare M753 Digital Camera
Lens won't collapse and go back in camera
I can't get lens to close.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 28, 2010
SOURCE: Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Posted on Apr 22, 2008
t00nz
  • 4738 Answers
SOURCE: "Lens error, restart camera." The lens won't close,
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to corr
ect it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 05, 2009
t00nz
  • 4738 Answers
SOURCE: camera lens dont close
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Posted on Jul 01, 2009
shockwave727
  • 262 Answers
SOURCE: zoom lens stuck out
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Posted on Nov 12, 2009
sonyfsd
  • 153 Answers
SOURCE: Lens is stuck and camera will not turn on.
there is a problum in your lenze block (optical assy) this problum is not remove at home so please go to your nearst sony service centre & repair the lenze block because no the child parts are avalable
Posted on Feb 12, 2010
Camera lens wont close
That is a lens error. Please see this video for troubleshooting steps.
Jun 08, 2013 | Cameras
Lens error restart camera canon SX10IS
Here are some troubleshooting steps for a lens error. And here's a video summary of those steps:
Jan 23, 2013 | Canon Cameras
Sony cyber-shot dsc-w570 lens cover won't close
Lens block is faulty you must replace it with a new one
Nov 04, 2011 | Sony Cyber-Shot DSC-W570 Digital Camera
I dropped the camera and the zoom lens got off line. It won't close or go back in the camera. It looks stuck and I tried pushing it in but I'm afraid that I might push hard that it'll break...
The lens may be fixable but most likely will need to be replaced.
If the lens is stuck straight or won't come out at all it needs to be replaced.
If the lens is stuck at an angle then you may be able to snap it back to the center by pressing the edge of the lens back towards center while holding on the outer ring of the lens.
Hope this helps!
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
My SL502 camera's lens won't open or close properly is there a way to fix it?
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Jun 28, 2011 | Samsung SL502 Digital Camera
My lens on my Olympus EPL1 will not retract, can you help?
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 29, 2010 | Olympus PEN EPL1 Digital Camera
MY LUMIX CAMERAS LENS WON'T CLOSE
Try rapping the camera bottom smartly against the heel of your hand to try to free it. If not, try rapping it less smartly on a harder surface, like a table covered with a bath towel. Do not rap the lens itself.
If this works but only some times, apply graphite lub to the sides of and extended lens at the collapsing joint sections, sparingly. Then get it to collapse and open a few time and wipe off lens with dust cloth.
If still no luck, sell yours to a repairman in an ebay auction, keeping your accessories. Then by a working replacement without accessories cheap.
Dec 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
220 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
