Question about Technics SA-TX1010
My receiver keeps overloading even when the speakers are not hooked up the model is satx1010, what should I do?
techman
  • 3130 Answers
SOURCE: Overloading
What speakers are you using? Are they seperate from the TV set? How is the audio attached to the TV set. What inputs I mean are you using for the speakers and the sound for the TV set?
Posted on Dec 09, 2006
  • 319 Answers
SOURCE: Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Posted on Aug 14, 2008
SOURCE: System is saying overload more frequently
Blow all the dust out of the unit with compressed air to prevent over heating (overload)
Posted on Dec 11, 2008
SOURCE: jvc receiver OVERLOAD
possible short across speaker wires somewhere or even inside speaker
Posted on Jan 23, 2009
Sparky2012
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
I have Wharfdale 4000 Xarus speakers connected to my Pioneer VSX 817, the last 6 months it keeps saying overload when i have the volume further than 40db. Never use to do it... and i have re wired the...
Testing your amp at max with the speakers disconnected will not play a factor because there is no power being drawn so the amp is not being used. Those speakers are rated 90db and really pound but also draw a ton of amps. The key thing here is to keep it cool, cool, cool. Put a fan on it and keep your receiver on a hard surface with nothing stacked on top or anywhere within a foot of it. Keeping it cool will help prevent overloads or (protection mode). Back it down every now and them and give the system a rest for a few minutes. Double check the negative and positive connection on the speakers to the receiver. We all have hooked them up backwards sometime and this will have the effect you are expressing. What is the phase set at on your receiver? Set it down to "0" and go up to where it sounds best without distortion. One more very important thing. What is the Ohm switch on your receiver set at? Put the switch on 8 Ohm even though your running 6 Ohm speakers. That switch only steps down your voltage feed to the power selections which will hamper the overall dynamics and fidelity of your receiver. This switch is really not even necessary. Putting that switch at 8 Ohms will give you more headway and aid in keeping your amp cool.
Regards, Tony
Mar 24, 2011 | Pioneer VSX-817-S
When i turn the power on my receiver it turns off in about two minutes = overload, this occurs when nothing is even hooked up to it.
If no speakers are hooked up to it, then the unit has internal damage. It works only until the damaged portion overheats. The safety relay trips in order to protect the rest of the receiver. Take it to a qualified technician. Even if the speakers are disconnected, make sure no cable leads were left in the connectors, shorting the output.
Mar 14, 2010 | Audio Players & Recorders
Dec 04, 2009 | Technics SA-AX530 Receiver
I have a technics sug91 amp the over load light comes on what can i do to remove it
you cant remove the overload light. it does that as a safty so you dont burn up the amp when its not being used properly. do u have a capacitor? are the speakers ohms and watts the same as the amp?
Oct 18, 2009 | Technics SA-AX540 Receiver
Every time I try to turn on my onkyo receiver it turns off instantly
the reason why the receiver probably keep turning off is that the systems come with overload protector to keep one from burning or short the systems out so it shut its self off. make sure you have the speaker wires is connected properly, its very important that you do although the receiver has 0% tolerance when it come to speakers hook up. positive from speaker to positive connector behind reciever; same as negative. double check all speakers wires. repost if that not an issue
Oct 03, 2009 | Onkyo TX-SR605 Receiver
New pioneer vsx-517 keeps going into overload
Fastest way to test is to disconnect all speakers and turn up the vol. If it clips it needs service, then re-connect 8ohm speakers one by one and test until you find the speaker or channel that shorts. Then take that same speaker and hook it up to another channel and test, if it shorts, you know now it is either the speaker or the wire. Now, use a new piece of speaker wire from the same channel that caused it to short, replace the old and test. If it shorts, you've got a problem with the speaker. If your handy with a multimeter, check the resistance at the speaker and you will have your answer. If you are not familliar with a multimeter, just hook up a different speaker where the bad one is and test. It's just process of elimination. Hope this helps
May 25, 2009 | Pioneer VSX-517
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
Jvc receiver OVERLOAD
Dec 21, 2007 | JVC RX-6000V Receiver
Overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
Overloading
Dec 08, 2006 | Pioneer VSX-516-K
95 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
